cgal-discuss - Re: Re: [cgal-discuss]Attach user data to the vertices of a Arrangement_2during construction
  • To: "" <>
  • Subject: Re: Re: [cgal-discuss]Attach user data to the vertices of a Arrangement_2during construction
  • Date: Fri, 30 Mar 2007 21:21:31 +0800
  • Disposition-notification-to: "Wang Weiwei" <>
You can use your own observer (derived from
CGAL::Arr_observer<Arrangement_2>). Look at face_extension.cpp to see
how it's done for faces.
Hello Fogel,
Thanks very much for your hints.
Yes, I found the example in ex_face_extension.C. But my needs seems not to be
fully met. To declare a class derived from CGAL::Arr_observer<Arrangement_2>,
and then override the before_create_vertex() method, I can capture the event
of the insertion of a new vertex. But still one problem is that there's only a
Arr_face_extended_dcel type in CGAL, no Arr_vertex_extended_dcel available. I
cannot associate data with the vertices as this way. The other problem is
that
the way I'm constructing the arrangement is like this:
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Arr_segment_traits_2<Kernel>
Traits_2;
typedef Traits_2::Point_2
Point_2;
typedef Traits_2::X_monotone_curve_2
Segment_2;
typedef CGAL::Arr_extended_dcel<Traits_2, int, int, int>Dcel;
typedef CGAL::Arrangement_2<Traits_2, Dcel>
Arrangement_2;
struct Point_2_with_id
int id;
float x, y;
std::vector<Point_2_with_id> points;
std::list<Segment_2> segments;
for(std::vector<Point_2_with_id>::const_iterator it=points.begin();
it != points.end(); ++it)
segments.push_back (
Segment_2 ( Point_2( it->x, it->y ), Point_2( /*some
other point*/ ) )
The user data (here means the id of a point) was discarded during cunstructing
a segment.
I think it would be better if I can derive a class from Point_2, and if I
can build the arrangement with the derive points.
Thanks again.
Max
Wang Weiwei wrote:
>Hi all,
>I'm using the Arrangement_2 module of CGAL.
>I want to attach some user information to the vertices of the arrangement.
>I've found some example code in the example folder of the CGAL lib (such as
>ex_dcel_extension.C).
>Unfortunately, in this example, the user data are attached to the vertices,
>halfedges and faces after the arrangement was built. What I want to know is
>how I can attach these user data to the vertices during the construction of
>the arrangement. For those vertices newly created during the intersection of
>the curves, a pre-specified default value will be ok.
>Thanks in advance for any help.
>Sorry for the previous message with the subject not correct.
>Max
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
