- To:
- Subject: Re: [cgal-discuss] Re: post condition errors with Convex_hull_3
- Date: Thu, 12 Apr 2007 13:50:39 +0200
Thank you for your answers.
I use the exact_predicates_inexacte_constructions kernel. I though that this kernel was enough to perform what I want: a convex hull of few points. I don't create any other points.. The very strange thing is when I disable the post conditions, I obtain only triangles as facets of my polyhedron so I don't understand why I can have the "strongly_convex" error.. The creation of the convex_hull is a part of a bigger program so I isolate the part and I try if I obtain the error: if it is the case I send the program and the sets of points.
Best Regards,
Matthieu Chavent
Andreas Fabri a écrit :
Hello,
Besides the question concerning the kernel you have chosen,
did you use the static, incremental, or dynamic version.
If the data set is not huge, please send me data set and
testprogram so that we can reproduce and fix it.
best regards,
andreas
Matthieu Chavent wrote:
I resolved my problem with compiling with -DCGAL_CH_NO_POSTCONDITIONS
and now it's work well but I would like to know how this problem appears
and if I disable this option it possible to have concave objects?
Thank you in advance!
Matthieu Chavent a écrit :
Hello cgal users!
I performed a convex hull of a set a 3D points. I know that the set of points define a convex volume. I use the function CGAL::convex_hull_3 on my points list. I obtain a Polyhedron_3 in almost cases but one time a have the error message:
CGAL error: postcondition violation!
Expr: is_strongly_convex_3(P, traits)
File: /home/Chavent_Matthieu/CGAL-3.2.1/include/CGAL/convex_hull_3.h
Line: 468
Aborted (core dumped)
It is very strange because I know that the sets of points that form the Polyhedron define a convex volume: So, I would like to know if somebody had the same problem and How can I get through this error.
Matthieu Chavent
LORIA
PhD student
tel: ++33(0)3-54-95-86-05
- post condition errors with Convex_hull_3, Matthieu Chavent, 04/12/2007
- Re: post condition errors with Convex_hull_3, Matthieu Chavent, 04/12/2007
- Re: [cgal-discuss] Re: post condition errors with Convex_hull_3, Andreas Meyer, 04/12/2007
- Re: [cgal-discuss] Re: post condition errors with Convex_hull_3, Andreas Fabri, 04/12/2007
- Re: [cgal-discuss] Re: post condition errors with Convex_hull_3, Matthieu Chavent, 04/12/2007
- Re: [cgal-discuss] Re: post condition errors with Convex_hull_3, Camille . Wormser, 04/12/2007
