cgal-discuss - Re: [cgal-discuss] Re: post condition errors with Convex_hull_3
  • To:
  • Subject: Re: [cgal-discuss] Re: post condition errors with Convex_hull_3
  • Date: Thu, 12 Apr 2007 15:49:17 +0200
I analyzed my set of points and I saw a problem: I had two points which were the same in "double" but when I checked if they were equal with CGAL (with == ) it was not the case. In fact, at the beginning I calculated some circumcenters of Delaunay cells and I have two Delaunay cells with the same circumcenter.. But CGAL considered the circumcenter as two points (points that cause problem for the convex_hull).. So, the problem is more a problem of interpretation of CGAL than a problem of convex_hull. I would like to keep the exact_constructions_inexact_predicates kernel (to have a faster program) and finally,I prefer to disable the post conditions..
Thanks everybody for the help!!
Matthieu.
a écrit :
Le Jeu 12 avril 2007 13:50, Matthieu Chavent a écrit :
I use the exact_predicates_inexacte_constructions kernel. I though that
this kernel was enough to perform what I want: a convex hull of few
points. I don't create any other points.. The very strange thing is when
I disable the post conditions, I obtain only triangles as facets of my
polyhedron so I don't understand why I can have the "strongly_convex"
error..
In fact, the is_strongly_convex_3 post-condition uses constructions. As
such, it is not robust with exact_predicates_inexact_constructions kernel.
Matthieu Chavent
LORIA
PhD student
tel: ++33(0)3-54-95-86-05
