- To:
- Subject: Re: [cgal-discuss] How to build a polyhedron?
- Date: Fri, 20 Apr 2007 16:37:44 +0200
Hello,
Reply-To:
To:
Date: Tue, 17 Apr 2007 18:52:14 +0200
Fred Fred wrote:
Basic question but soooo complicated to find a way to do it with CGAL documentation! I have been surfing in the doc for 3 hours and still have not reached it. Actually I have manage to create a triangulation of a terrain and now I would like to refine it. Unfortunately it seems that it is necessary to convert the triangulation to a polyhedron, so I would have expected a conversion method so as to create a polyhedron from my traingulation but either it does not exist or I did not find it.I don't see why you need to convert the triangulation into a polyhedron
So could anyone tell me how I could create a polyhedron from my triangulation in less than 3 hours?
Regards.
_________________________________________________________________
Découvrez le Blog heroic Fantaisy d'Eragon! http://eragon-heroic-fantasy.spaces.live.com/
to be able to refine your terrain.
See the example of terrain in the user manuel of Triangulation_2 : insertion are performed.
I did but only found the necessary material for reimplementing the subdivision (vertex insertion and so). But since different subdivision schemes have already been implemented in the librayry (eg loop scheme) I would have expected that they could be reused for my problem. But, as far as I did not miss anything, all the subdivision algorithms in CGAL deal with polyhedrons and not triangulations, right?
Another issue: it is very difficult to cope with the so numerous types defined in the library, particularly I made the following declarations:
struct Kdelaunay : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_euclidean_traits_xy_3<Kdelaunay> Gt;
typedef CGAL::Delaunay_triangulation_2<Gt> Delaunay;
Delaunay del;
And now I would like to copy the triangulation so as to insert new verticies but not under Delaunay constraints (I want to build a multiresolution model), so I wrote:
typedef CGAL::Triangulation_2<Gt> TDS;
but nor:
TDS tr(del);
neither:
TDS tr(del.geom_traits(), del.tds());
works, so probably there are some lacks in my C++ templates knowledge but HOW TO GET A COPY OF THE TRIANGULATION created by Delaunay??
thanks in advance for your help.
Windows Live Spaces : créez votre blog à votre image ! http://www.windowslive.fr/spaces
- How to build a polyhedron?, Fred Fred, 04/17/2007
- Re: [cgal-discuss] How to build a polyhedron?, Mariette Yvinec, 04/17/2007
- Re: [cgal-discuss] How to build a polyhedron?, Fred Fred, 04/20/2007
