- To:
- Cc: Bruno Levy <>
- Subject: Re: [cgal-discuss] Least Squares Conformal Maps parameterization
- Date: Mon, 23 Apr 2007 10:28:38 +0200
- Organization: INRIA Sophia-Antipolis
Dear Stavros,
You may implement a fixed border mean value coordinates parameterization (Floater) using CGAL and a specific .off mesh 2D border by:
* Adding a class that will implement the border parameterization that you
wish.
This class must be a model of BorderParameterizer_3 (see www.cgal.org/Manual/3.2/doc_html/cgal_manual/Surface_mesh_parameterization_ref/Concept_BorderParameterizer_3.html)
You may use the default circle or square border parameterizations as a starting point.
* Passing this new class as template parameter to CGAL::Square_border_arc_length_parameterizer_3 (Floater).
See Square_border_parameterization.cpp example to specify such a template
parameter.
Best regards,
Laurent Saboret
Stavros G. Papageorgiou a écrit :
thank you for your answer,>
hmm you are right.
any ideas or link to other sites on how to implement a fixed border mean value coordinates parameterization (Floater)
using CGAL and a specific .off mesh 2D border?
That is instead of the default circle or square border parameterization?
thanks again,
/n
----- Original Message ----- From: "Peter Schröder"
To:
Sent: Wednesday, April 18, 2007 3:56 PM
If you want to fix the border the LSQ conformal map will not be conformal anymore. You'll have to use another technique.
peter
>>> Hi to all,
Stavros G. Papageorgiou wrote:
>>> is there a way, or has anyone implemented
>>> a fixed border parameterization method for specific borders?
>>> That is, how can I produce a planar parameterization of a 3D surface using
>>> Least Squares Conformal Maps parameterization and CGAL but on a fixed
>>> 2D border of my choice?
- Least Squares Conformal Maps parameterization, Stavros G. Papageorgiou, 04/18/2007
- Re: [cgal-discuss] Least Squares Conformal Maps parameterization, Peter Schröder, 04/18/2007
- Re: [cgal-discuss] Least Squares Conformal Maps parameterization, Stavros G. Papageorgiou, 04/19/2007
- Re: [cgal-discuss] Least Squares Conformal Maps parameterization, Laurent Saboret, 04/23/2007
