cgal-discuss - Re: [cgal-discuss] how to improve spatial searching efficiency and reduce searching time?
  • To:
  • Subject: Re: [cgal-discuss] how to improve spatial searching efficiency and reduce searching time?
  • Date: Tue, 24 Apr 2007 13:55:33 +0200
Thetis,
Simply call the function build(). Considering your code:
Distance tr_dist;
// want to compute query time
tree.build(); //builds the tree!!!
DWORD dwStart = GetTickCount();
Neighbor_search N1( tree, query, K, 0.0, false); // eps=10.0, nearest=false
DWORD dwEnd = GetTickCount();
Cheers,
Johannes
thetis guan wrote:
Hi Johannes
thank you for your answer..but i do not know how to build the kd tree manually. please explain it clearly or give me a sample!
thank you very much!
Cheers,
thetis
On 4/20/07, *Johannes Otepka* < <mailto:>> wrote:
Thetis,
If you really want to measure the "true" search time, you have to
build the kd tree manually. otherwise it's done automatically
during the first spatial (search) operation which is why all your
different tests result in more or less to the same computation time.
I have no experince with CGAL::Cartesian*_d *Kernel, the Manhattan
distance and furtherst neigbour searching. However the building
time of 30s for 200000 Points seems to me quite slow. I use the
'normal' CGAL::Cartesian for 2D and 3D kd tree's. On my 2 years
old notebook a kd tree of about 2 Mio Pts takes ca..10 sec to build.
Cheers,
Johannes
thetis guan wrote:
Dear all:
I have a question about efficiency of dD Spatial Searching. that
is, give a query item /q / the points of* P *set can not browsed
efficiently.
My operating system is MS XP; compiler is MS Visual8.0(.NET2005),
toolkit of CGAL is Release3.2;
For example:
I set a set* P* of data points including 200000 points. I want to
find a query point */q/ *in set* P . *
Both Neighbor searching and Range searching which I had a try to
test. Searching time is about 30s. In Neighbor searching, I
respectively use four classes to test:
CGAL::Orthogonal_k_neighbor_search,
CGAL::Orthogonal_incremental_neighbor_search, CGAL::
k_neighbor_search, CGAL:: Incremental _neighbor_search. Among the
tests, I give different splitting rules and bucket size, such as
Sliding_midpoint, Fair, Sliding_fair, ect.
Although time of these test are different, these differences are
little. Searching time always about 30s.
I think the searching time is too long, but I do not know how to
improve searching efficiency and reduce searching time.
Could you please shed some light on this?
Thanks in advance and best regards!
I execute all of examples of General neighbor searching described
in cgal-manual. And one of examples Codes as below:
#include <CGAL/basic.h>
#include <CGAL/Cartesian_d.h>
#include <CGAL/point_generators_2.h>
#include <CGAL/Manhattan_distance_iso_box_point.h>
#include <CGAL/K_neighbor_search.h>
#include <CGAL/Search_traits_2.h>
#include <Windows.h >
#include <time.h >
using namespace std ;
typedef CGAL:: Cartesian_d <double> K;
typedef K:: Point_d Point_d;
typedef CGAL:: Random_points_in_square_2 <Point_d>
Random_points_iterator;
typedef K:: Iso_box_d Iso_box_d;
typedef K TreeTraits ;
typedef CGAL:: Manhattan_distance_iso_box_point <TreeTraits>
Distance;
typedef CGAL:: K_neighbor_search <TreeTraits, Distance>
Neighbor_search;
typedef Neighbor_search:: Tree Tree;
int _tmain( int argc, _TCHAR* argv[])
const int N = 200000; //set P including N points
const int K = 10; //search K points
Tree tree;
Random_points_iterator rpg; //generator random N points
for(int i = 0; i < N; i++)
tree.insert(* rpg++); //add point to kd-tree
//define query item
Point_d pp(0.1,0.1);
Point_d qq(0.2,0.2);
Iso_box_d query( pp, qq);
Distance tr_dist;
DWORD dwTimeTaken = dwEnd - dwStart; //this is
query time result
std::cout << "For query rectange = [0.1, 0.2]ˆ2 " << std::endl
<< "The " << K << " approximate furthest neighbors
are: " << std::endl;
for (Neighbor_search:: iterator it = N1.begin();it != N1.
end(); it++)
std:: cout << " Point " << it->first << " at
distance = " << tr_dist.
inverse_of_transformed_distance(it->second) << std:: endl;
return 0;
