cgal-discuss - how to improve spatial searching efficiency and reduce searching time?
  • To:
  • Subject: how to improve spatial searching efficiency and reduce searching time?
  • Date: Thu, 19 Apr 2007 09:42:26 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:mime-version:content-type; b=OvFWUqiL/wyVraM5Zr1T2WXLIsUme6hsOATO/+sDMJ/wjc7w63lN4YS2yIpfNQoqSKCdQl0UCbPdi0QHrqkfSO6ZJQYLTk6MMnhizVUmszOMy41BFitPInPjclyX1HDODw32LtkK8pTwSJO5XjkeOq9kytvTsXie1FKZ+axYFOw=
Dear all:
I have a question about efficiency of dD Spatial Searching. that is, give a query item q  the points of P set can not browsed efficiently.
My operating system is MS XP; compiler is MS Visual8.0(.NET2005), toolkit of CGAL is Release3.2;
For example:
I set a set P of data points including 200000 points. I want to find a query point q in set P .
Both Neighbor searching and Range searching which I had a try to test. Searching time is about 30s. In Neighbor searching, I respectively use four classes to test: CGAL::Orthogonal_k_neighbor_search, CGAL::Orthogonal_incremental_neighbor_search, CGAL:: k_neighbor_search, CGAL:: Incremental _neighbor_search. Among the tests, I give different splitting rules and bucket size, such as Sliding_midpoint, Fair, Sliding_fair, ect.
Although time of these test are different, these differences are little. Searching time always  about 30s.
I think the searching time is too long, but I do not know how to improve searching efficiency and reduce searching time.
Could you please shed some light on this?
Thanks in advance and best regards!
I execute all of examples of General neighbor searching described in cgal-manual. And one of examples Codes as below:
#include <CGAL/basic.h>
#include <CGAL/Cartesian_d.h>
#include <CGAL/point_generators_2.h>
#include <CGAL/Manhattan_distance_iso_box_point.h>
#include <CGAL/K_neighbor_search.h>
#include <CGAL/Search_traits_2.h>
#include  <Windows.h >
#include  <time.h >
using namespace std ;
typedef CGAL::Cartesian_d <double> K;
typedef K::Point_d Point_d;
typedef CGAL::Random_points_in_square_2 <Point_d> Random_points_iterator;
typedef K::Iso_box_d Iso_box_d;
typedef K TreeTraits ;
typedef CGAL::Manhattan_distance_iso_box_point <TreeTraits> Distance;
typedef CGAL::K_neighbor_search <TreeTraits, Distance> Neighbor_search;
typedef Neighbor_search:: Tree Tree;
int _tmain(int argc, _TCHAR* argv[])
       const int N = 200000; //set P including N points
       const int K = 10; //search K points
       Tree tree;
       Random_points_iterator  rpg;   //generator random N points
       for(int i = 0; i < N; i++)
              tree.insert(*rpg++); //add  point to kd-tree
     //define query item
       Point_d pp(0.1,0.1);
       Point_d qq(0.2,0.2);
       Iso_box_d query(pp, qq);
       Distance tr_dist;
// want to compute query time
       DWORD   dwStart    =   GetTickCount();
       Neighbor_search N1(tree, query, K, 0.0, false); // eps=10.0, nearest=false
       DWORD   dwEnd    =   GetTickCount();
       DWORD   dwTimeTaken    =   dwEnd   -   dwStart; //this is query time result
       std::cout << "For query rectange = [0.1, 0.2]ˆ2 " << std::endl
              << "The " << K << " approximate furthest neighbors are: " << std::endl;
       for (Neighbor_search::iterator it = N1.begin();it != N1.end(); it++)
                     std::cout << " Point " << it->first << " at distance = " << tr_dist. inverse_of_transformed_distance(it->second) << std:: endl;
       return 0;
