- To:
- Subject: Re: [cgal-discuss] KD tree "bug"?
- Date: Mon, 30 Apr 2007 21:57:59 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=P6a97k0H+FaKr7dPhguxtZBRX+nG74oHdnPV/3mf9i2mUHo3vo8fJx/ZPfn8rghmASO6/dfy1vCZ/9Le5AhRM3oXjIvgyalOEHQ1GJXd4phzc09SKa6yvauZfcPt5hCtW1ZcU+/Shfbytmto1AMORiqkLuD1WCgx3kuS2iWsbpw=
hi Yajun Wang
do you use .Net2005? if you do, please add some assert sentence!
in your solution,
In in "C/C++ | Preprocessor" Add
_CRT_SECURE_NO_DEPRECATE
_SECURE_SCL=0
_HAS_ITERATOR_DEBUGGING=0
to Preprocessor Definitions for both Debug and Release.
cheers,
thetis
On 4/29/07, Yajun Wang <> wrote:
Hi cgal developers:
I am using CGAL::Incremental_neighbor_search<Traits, GeneralDistance,
Splitter, SpatialTree> to do neighbor search. It turns out that if the
Tree's size is 0, cgal will produce segment fault (the latest
version). Is it possible to put an assertion check in the cgal code so
that it is more visible to the users?
thanks for the effort.
regards,
yalding
- KD tree "bug"?, Yajun Wang, 04/29/2007
- Re: [cgal-discuss] KD tree "bug"?, thetis guan, 04/30/2007
- Re: [cgal-discuss] KD tree "bug"?, Yajun Wang, 04/30/2007
