- To:
- Subject: binary operation between 3d nef polyhedron
- Date: Wed, 02 May 2007 11:38:24 +0200
Hello everybody,
I first want to thanks all the CGAL developers : my program which use CGAL 3d nef module begins to give the result I expected :-). But... I still have 2 questions :
1) In the binary operation between two 3d nef polyhedrons :
During execution, just at the end of the function "binary_operation" (Line 1245 in SNC_decorator.h) the assertion "sim.simplify" is (sometime) not true and the program ends !
I would like to know if somebody already had this problem...
What mean the assertion "simplify" (I didn't find an explanation in the CGAL documentation) ?
2) How can I convert a Nef_Polyhedron_3 which is not simple (a face has a hole in it) in a Polyhedron_3 (which I visualize later in VRML format) ?
Is there already a simple procedure which do so or do I have to program an algorithm ( which for example triangulate the non-simple-face ) ?
Thanks in advance.
Olivier.
- binary operation between 3d nef polyhedron, olivier stab, 05/02/2007
- Re: [cgal-discuss] binary operation between 3d nef polyhedron, Peter Hachenberger, 05/02/2007
- Re: [cgal-discuss] binary operation between 3d nef polyhedron, olivier stab, 05/02/2007
- Re: [cgal-discuss] binary operation between 3d nef polyhedron, Andreas Meyer, 05/02/2007
