cgal-discuss - Re: [cgal-discuss] binary operation between 3d nef polyhedron
  • To:
  • Subject: Re: [cgal-discuss] binary operation between 3d nef polyhedron
  • Date: Wed, 02 May 2007 15:22:40 +0200
On Wed, 2007-05-02 at 15:06 +0200, olivier stab wrote:
> Hi Peter,
> Thank you for your quick answer.
> Peter Hachenberger a écrit :
> > Hi Olivier,
> > On Wed, 2007-05-02 at 11:38 +0200, olivier stab wrote:
> >> Hello everybody,
> >> I first want to thanks all the CGAL developers : my program which use
> >> CGAL 3d nef module begins to give the result I expected :-). But... I
> >> still have 2 questions :
> >> 1) In the binary operation between two 3d nef polyhedrons :
> >> During execution, just at the end of the function "binary_operation"
> >> (Line 1245 in SNC_decorator.h) the assertion "sim.simplify" is
> >> (sometime) not true and the program ends !
> >> I would like to know if somebody already had this problem...
> >> What mean the assertion "simplify" (I didn't find an explanation in the
> >> CGAL documentation) ?
> > Actually, this assertion should not occur. Probably, you are not doing
> > wrong, here. Can you send me the files that cause the problem and tell
> > me which binary operation you apply on them and which Kernel you use.
> > Then I try to find the error.
> I am using Simple_cartesian/Gmpq kernel.
> As I am writing this Email, I am modifying my code to save (in ascii
> files) the 2 nefs that cause the problem. But as I am using such a
> Kernel the 2 files may be heavy. It's probably better not to send it to
> everybody in the cgal-discuss list... If you aggree, I'll send them to
> you directly at you email adress at Eindhoven University. Just tell me...
I guess you need a cartesian kernel, but I must tell you, that Nef_3
runs much faster with a Homogeneous kernel. With the next release, you
can use filtering with Nef_3. Then the efficiency of the cartesian
kernel will be much better.
Just send the files to my eindhoven address. That's OK.
> Do you think it will be in the next release of CGAL ?
> Thanks.
No, the next release is too close.
