cgal-discuss - Re: [cgal-discuss] Re: Cannot access to Polygon_2 points
  • To:
  • Cc:
  • Subject: Re: [cgal-discuss] Re: Cannot access to Polygon_2 points
  • Date: Fri, 11 May 2007 11:30:36 +0200
  • Organization: Inria, Sophia Antipolis, FRANCE
On Friday 11 May 2007 03:04:00
wrote:
> Ok i have founded the Vertex_iterator to access the vertex of the Polygon
> Vertex_iterator vertit;
> vertit = polygon.vertices_begin ();
> double x1 = vertit->x();
> double x2 = vertit->y();
> but the manual say into Polygon_2
> Point_2 pgn [ int i] Returns a (const) reference to the
> i-th
> vertex.
More precisely, the manual says:
Random access methods
These methods are only available for random access containers.
Point_2 pgn.vertex ( int i)
Returns a (const) reference to the i-th vertex.
http://www.cgal.org/Manual/3.2/doc_html/cgal_manual/Polygon_ref/Class_Polygon_2.html
The important part is "only available for random access containers".
I had a look at your error messages, and the Container template parameter of
Polygon_2 was instantiated with a list. As the container do not have random
access iterators, you cannot have them at the polygon level either.
If you instantiate you polygon type like that: "CGAL::Polygon_2<Traits>",
that
is without specifying the Container parameter, the container will be a
std::vector, which has random access iterators.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
