cgal-discuss - Re: [cgal-discuss] Intersection between Delaunay facet and its dual edge
  • To:
  • Subject: Re: [cgal-discuss] Intersection between Delaunay facet and its dual edge
  • Date: Tue, 22 May 2007 18:40:20 +0800
  • Organization: Dept of CSE, HKUST
FYI: The Voronoi edge does not necessarily intersect its dual.
regards,
yalding
Tardugno, Angelo 写道:
> Hi CGAL experts,
> I've been trying to compute the intersection between a Delaunay facet
> and ist dual (Voronoi Edge). This operation should result in a point,
> but, surprisingly sometimes (actually very frequently) it returns
> something different.
> Here's part of my code:
> Finite_cells_iterator ci=T.finite_cells_begin();
> out_stream.open("Vvertex");
> o_stream.open("s3points");
> o1stream.open("triangle");
> o2stream.open("segment");
> for (;ci !=T.finite_cells_end(); ++ci)
> voronoi_vertices = (T.dual(ci));
> out_stream << 4 << " " << voronoi_vertices << "\n";
> // Finding the dual of each facet of the delaunay triangulation
> (Voronoi edge)
> // and compute its intersection with the facet in case the triangle
> // is acute
> for (int i=0; i<4; i++)
> CGAL::Object o = T.dual(ci,i);
> K::Triangle_3 t = T.triangle(ci,i);
> CGAL::Object o2;
> K::Segment_3 s,s2;
> K::Ray_3 r;
> K::Plane_3 plane;
> K::Point_3 point;
> K::Construct_supporting_plane_3 construct_plane;
> if (is_acute(t))
> if (CGAL::assign(s,o))
> //cout << i << "\n";
> o1stream << t << "\n";
> o2stream << s << "\n";
> plane = construct_plane(t); // Building the supporting
> plane for the triangle
> o2 = intersection(s,plane); // Evaluating intersection
> between voronoi edge and plane
> if (assign(point,o2)) // Assigning object intersection to
> point
> xx = (point.x());
> yy = (point.y());
> zz = (point.z());
> out_stream << 3 << " " << xx << " " << yy << " " << zz << "\n";
> n_of_s3_points++;
> } else
> cout << "Something different\n";
> if (CGAL::assign(r,o))
> point
> xx = (point.x());
> yy = (point.y());
> zz = (point.z());
> o_stream << 3 << " " << xx << " " << yy << " " << zz << "\n";
> n_of_s3_points++;
> } else
> else cout << "\nObtuse Angle\n";
> o1stream.close();
> o2stream.close();
> o_stream.close();
> out_stream.close();
> After running this program, I checked the files triangle and segment but
> when I check for the first triangle and the first segment it seems like
> the segment isn't the actual dual of the Delaunay facet, since there is
> no intersection between the two. Maybe I've made a mistake when I
> created the dual of the facet or the triangle describing the facet.
> Anyway, I've tried my best to understand what's happening but I have no
> clue.
> Anybody can help?
> Thanks
> Angelo Tardugno
