Re: [cgal-discuss] How to retrieve handles of vertices which constitute an edge in a 3D triangulation?
- To:
- Subject: Re: [cgal-discuss] How to retrieve handles of vertices which constitute an edge in a 3D triangulation?
- Date: Tue, 22 May 2007 08:37:42 -0500
Dear Monique,
Thank you for answering my question! Yes, I'd seen your previous
answer. I thought originally that even incident vertices are given, I
still have to compute pairwise set intersection of their incident
cells, and loop over the cell indices to find out one representation
of the incident edge. I looked the reference manual more carefully,
and found this method that retrieves an edge (if it exists), given two
vertex handles.
bool tds.is_edge ( Vertex_handle u,
Vertex_handle v,
Cell_handle & c,
int & i,
int & j)
This is what I need, and my current problem is solved. Thank you very
much for the help!
best,
Jingyi
On 5/22/07,
wrote:
Hi Jingyi,
What about my previous answer (see attachment)?
Edges are not explicitely stored in a 3d triangulation.
We provide a way to get all incident vertices.
We could provide also a function giving a representative of each
incident edge, but it is not implemented... I guess it is quite easy to
implement, looking at the code of incident_vertices.
Best,
Monique Teillaud
Jingyi Jin wrote:
> Hi,
> Following a previous post to ask one question..
> On 5/4/07,
wrote:
>> In 2D, having an edge circulator is natural and meaningful: edges are
>> ordered around a vertex. In 3D edges are not circularly ordered around a
>> vertex.
> If I want to retrieve all incident edges of a vertex, what is the best
> way to do that? The order does not matter in my application.
> Thanks a lot!
> Jingyi
- How to retrieve handles of vertices which constitute an edge in a 3D triangulation?, Matthieu Chavent, 05/04/2007
- Re: [cgal-discuss] How to retrieve handles of vertices which constitute an edge in a 3D triangulation?, Monique . Teillaud, 05/04/2007
- Re: [cgal-discuss] How to retrieve handles of vertices which constitute an edge in a 3D triangulation?, Rajdeep Mukherjee, 05/06/2007
- Re: [cgal-discuss] How to retrieve handles of vertices which constitute an edge in a 3D triangulation?, Jingyi Jin, 05/22/2007
- Re: [cgal-discuss] How to retrieve handles of vertices which constitute an edge in a 3D triangulation?, Monique . Teillaud, 05/22/2007
- Re: [cgal-discuss] How to retrieve handles of vertices which constitute an edge in a 3D triangulation?, Monique . Teillaud, 05/23/2007
