- To:
- Subject: Re: Re: [cgal-discuss] 3D Surface mesher
- Date: Thu, 24 May 2007 04:54:55 +0200
Dear Laurent,
Thanks for your answer.
> All the surfacic information are in the object c2t3. See the documentation,
> for that class:
I managed to get the surfacic information.
But I am not sure why facet iterator variable for c2t3 does not work without
initializing it.
If I try to compile the following fragment of code,
C2t3::Facet_iterator it;
the compiler (VC7) complains like
"error C2512:
'CGAL::Complex_2_in_triangulation_3<Tr>::Iterator_not_in_complex' ".
On the other hand, the following one can be compiled without any claims
C2t3::Facet_iterator it = c2t3.facets_begin();
Am I doing something wrong?
> If you want to recreate a surface from a set of points, you need a surface
> reconstruction algorithm. As far as I know, the only one that is publicly
> available in CGAL is the alpha shape.
Could the reconstructed shape be input for the function make_surface_mesh?
or do we have another way to make surface mesh from the shape?
My goal is to create surface mesh from given points written in a file.
I think one way to do that is to convert the file format to INRIMAGE, GIS or
ANALYZE one if their file format opens.
Best regards,
Momo
- Re: Re: [cgal-discuss] 3D Surface mesher, momokeke50, 05/24/2007
- Re: [cgal-discuss] 3D Surface mesher, Laurent Rineau, 05/24/2007
- <Possible follow-up(s)>
- Re: Re: [cgal-discuss] 3D Surface mesher, momokeke50, 05/25/2007
