cgal-discuss - Re: Re: [cgal-discuss] 3D Surface mesher
  • To:
  • Subject: Re: Re: [cgal-discuss] 3D Surface mesher
  • Date: Fri, 25 May 2007 05:05:28 +0200
Dear Laurent,
Thank you very much again for your kind answer.
> No. The reconstructed shape already is a kind of surface mesh. What do you
> want to achieve? Re-mesh it?
Yes, I would like to re-create surface mesh with a refined shape criteria.
Points and connectivities of the points for triangulations are given in a
file such as Object File Format (OFF). The points approximate a 3D surface
model. Adding some points on the surface, I would like to obtain more
beautiful surface mesh. What I would like to do is similar to the example
which can be found in examples/Mesh_2/conforming.C.
Best regards,
Momo
