- To: <>
- Subject: Re: [cgal-discuss] Problem with the installation of CGAL in Visual Studio 2005
- Date: Fri, 01 Jun 2007 13:43:43 -0300
Hello,
> My IDE is Microsoft Visual Studio 2005 and my parameters are in the
> tools->options->VC++ Directories :
> -include files : C:\boost\boost_1_34_0\ and $(CGALROOT)\include and
> $(CGALROOT)\include\CGAL\config\msvc7
> -library files : C:\boost\boost_1_34_0\libs and $(CGALROOT)\lib\msvc7
It seems you had an earlier version of CGAL already installed.
It also seems that you created a project file of your own (instead of using
the .vcproj provided)
Starting from Version 3.3, VC8.0 (Visual Studio 2005) is supported besides
VC7.1, thus, the folder "msvc7" is now named "msvc".
Can you correct the VC++ directories accordingly and report back if it works
now?
This issue is described in the document "INSTALL.win32.txt", at the very
bottom.
Please read all the release notes in that document to become aware of the
other important differences with respect to previous versions of CGAL.
HTH
Fernando Cacciola
GeometryFactory
__________________________________________________
Datafull - 100% Internet Gratis
http://www.datafull.com
- Re: [cgal-discuss] Problem with the installation of CGAL in Visual Studio 2005, fernando_cacciola, 06/01/2007
