- To: <>
- Subject: Re: [cgal-discuss] Problem with the installation of CGAL in Visual Studio 2005
- Date: Fri, 1 Jun 2007 14:22:39 -0300
- Organization: SciSoft
Hello,
My IDE is Microsoft Visual Studio 2005 and my parameters are in theIt seems you had an earlier version of CGAL already installed.
tools->options->VC++ Directories :
-include files : C:\boost\boost_1_34_0\ and $(CGALROOT)\include and
$(CGALROOT)\include\CGAL\config\msvc7
-library files : C:\boost\boost_1_34_0\libs and $(CGALROOT)\lib\msvc7
It also seems that you created a project file of your own (instead of using
the .vcproj provided)
Starting from Version 3.3, VC8.0 (Visual Studio 2005) is supported besides
VC7.1, thus, the folder "msvc7" is now named "msvc".
Can you correct the VC++ directories accordingly and report back if it works
now?
This issue is described in the document "INSTALL.win32.txt", at the very
bottom.
Please read all the release notes in that document to become aware of the
other important differences with respect to previous versions of CGAL.
HTH
Fernando Cacciola
GeometryFactory
- Problem with the installation of CGAL in Visual Studio 2005, pat, 06/01/2007
- Re: [cgal-discuss] Problem with the installation of CGAL in Visual Studio 2005, Fernando Cacciola, 06/01/2007
