cgal-discuss - Need help setting CGAL on MacOSX
  • To:
  • Subject: Need help setting CGAL on MacOSX
  • Date: Fri, 8 Jun 2007 23:31:51 -0500
Dear All,
I am installing CGAL on MacOS 10.4.9 using i386_Darwin-8.9 gcc compiler GNU 4.0.1.
I installed boost and all is well. However, I compiled the libraries and I got a small problem at the end of the creation of the last library as follows where libCGALCore shared failed to build as shared library. I thank anyone that can help me understand this problem.
Thank you in advanced.
Gamal
OS:
i386_Darwin-8.9
COMPILER: GNU 4.0.1
BOOST: supported
(1.34.0)
BOOST_PROGRAM_OPTIONS: supported (1.34.0)
BOOST_BIMAP: not supported
X11:
supported (11.0)
GMP:
supported (4.1.4)
GMPXX: not supported
MPFR:
supported (2.2.0)
ZLIB:
supported (1.2.3)
BLAS:
supported (unknown version)
LAPACK: supported
(unknown version)
ATLAS: not
supported
LEDA: not
supported
LEDAWIN: not supported
OPENGL: supported
(1.4)
QT: not
supported
TAUCS: not supported
Generating Makefiles ... done.
Building libCGAL static ... done.
Building libCGAL shared ... done.
Building libCGALimageIO static ... done.
Building libCGALimageIO shared ... done.
Building libCGALPDB static ... done.
Building libCGALPDB shared ... done.
Building libCGALCore static ... done.
Building libCGALCore shared ...
Compilation of libCGALCore shared failed.
You will be shown a log now ...
** Please press <ENTER> to continue. **
/usr/bin/g++ -fno-common -O2 -Wall -frounding-math '-I/Volumes/ Uranium/Codes/CGAL-3.3/include/CGAL/config/i386_Darwin-8.9_g++-4.0.1' '-I/Volumes/Uranium/Codes/CGAL-3.3/include' -I/usr/local/include/ boost-1_34 -I/usr/X11R6/include -DCGAL_USE_F2C -c GmpIO.cpp/usr/ bin/g++ -dynamiclib -install_name '/Volumes/Uranium/Codes/CGAL-3.3/ lib/i386_Darwin-8.9_g++-4.0.1'/libCGALcore++.dylib -o ''libCGALcore+ +.dylib \ CoreAux.o extLong.o CoreDefs.o CoreIO.o BigFloat.o Real.o Expr.o GmpIO.o \ '-L/Volumes/Uranium/Codes/CGAL-3.3/lib/ i386_Darwin-8.9_g++-4.0.1' -L/usr/local/lib -lgmp -lmpfr ld: common symbols not allowed with MH_DYLIB output format with the - multi_module option/usr/local/lib/libgmp.a(mp_bpl.o) definition of common ___gmp_junk (size 16)/usr/bin/libtool: internal link edit command failedmake: *** [libCGALcore++.dylib] Error 1make: Target `shared_lib' not remade because of errors.
