cgal-discuss - Re: [cgal-discuss] 3D surface meshing
  • To:
  • Subject: Re: [cgal-discuss] 3D surface meshing
  • Date: Wed, 13 Jun 2007 01:52:30 +0300
For god's shake, creating a surface from a point cloud it is not about "passing the point set to a function"...There are people that are doing their Phd's(not me, just for the record), in order to tackle the problem in a robust, efficient manner.
All the best in your research efforts but having something out of nothing has never worked...Please try to have the overview and do not get disappointed if it does not work in the first go.
Best regards
Ioannis
2007/6/12, Mahbubunnabi Tamal <>:
On 11/06/07, Laurent Rineau <> wrote:
On Monday 11 June 2007 17:15:52 Mahbubunnabi Tamal wrote:
> Hi
> Since I am very new to the field, I would be very grateful if you could
> please provide
> some sort of example for 3D surface meshing from clouds of points.
As I told you, we (CGAL developers) have code already implemented for that.
There exists litterature about implicit functions computed from a set of
points, but it is not implemented in CGAL.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
 The vertices defined by x,y and z coordinates
  x1 y1 z1
  xN yN zN
are already on the surface or extracted from the surface (noise free). I just need to do 3D surface meshing using these coordinates. After reading these coordinates from a text file I am having problem to pass them on to the function
Surface_3 surface(sphere_function,              // pointer to function
                    Sphere_3(CGAL::ORIGIN, 2.)); // bounding sphere
I am not sure how to use the pointer to the function. I guess the 'function' should be a 3D coordinates. How could I use these points in surface meshing?
Regards
Tamal
