- To:
- Subject: Re: [cgal-discuss] Polytope_distance_d error
- Date: Sun, 10 Jun 2007 18:09:18 +0200
MiTcX wrote:
hi all,
i've a little problem when i try to compute the Polytope_distance_d
between two polygons.
here is my code :
struct Kernel : public CGAL::Cartesian<float> {};
My previous suggestion to replace this with
Cartesian<CGAL::MP_Float> or Cartesian<CGAL::Gmpzf>
is wrong, since the number types in question are not
field types. Homogenous<CGAL::MP_Float> or
Homogenous<CGAL::Gmpzf> are appropriate kernels
here (see also attached file that works with CGAL 3.3).
Sorry about that.
Bernd.
#include <iostream> #include <CGAL/Homogeneous.h> #include <CGAL/Gmpzf.h> #include <CGAL/Polygon_2.h> #include <CGAL/Polytope_distance_d.h> #include <CGAL/Polytope_distance_d_traits_2.h> typedef CGAL::Homogeneous<double> Kernel; typedef CGAL::Polytope_distance_d_traits_2<Kernel, CGAL::Gmpzf, double> TraitsPolytope; typedef CGAL::Polytope_distance_d<TraitsPolytope> Polytope_distance; typedef Kernel::Point_2 Point_2; typedef CGAL::Polygon_2<Kernel> Polygon_2; int main() { Polygon_2 p; p.push_back(Point_2(444,607)); p.push_back(Point_2(445,97)); p.push_back(Point_2(448,92)); p.push_back(Point_2(449,610)); Polygon_2 p1; p1.push_back(Point_2(212,91)); p1.push_back(Point_2(448,92)); p1.push_back(Point_2(445,97)); p1.push_back(Point_2(213,96)); Polytope_distance dist2 (p.vertices_begin(), p.vertices_end(), p1.vertices_begin(), p1.vertices_end()); std::cout<< "dist : " << CGAL::to_double(dist2.squared_distance_numerator())/ CGAL::to_double(dist2.squared_distance_denominator()) <<std::endl; return 0; }
- Polytope_distance_d error, MiTcX, 06/09/2007
- Re: [cgal-discuss] Polytope_distance_d error, Bernd Gaertner, 06/10/2007
- Re: [cgal-discuss] Polytope_distance_d error, Julien., 06/10/2007
