- To:
- Subject: Re: [cgal-discuss] Polytope_distance_d error
- Date: Sun, 10 Jun 2007 18:42:52 +0200
thank's a lot Bernd,
i will try this.
maybe your little example should be placed on this page :
http://www.cgal.org/Manual/3.2/doc_html/cgal_manual/Optimisation_ref/Class_Polytope_distance_d.html#Cross_link_anchor_1036
Julien.
Bernd Gaertner a écrit :
MiTcX
wrote:
hi all,
i've a little problem when i try to compute the Polytope_distance_d
between two polygons.
here is my code :
struct Kernel : public CGAL::Cartesian<float> {};
My previous suggestion to replace this with
Cartesian<CGAL::MP_Float> or Cartesian<CGAL::Gmpzf>
is wrong, since the number types in question are not
field types. Homogenous<CGAL::MP_Float> or
Homogenous<CGAL::Gmpzf> are appropriate kernels
here (see also attached file that works with CGAL 3.3).
Sorry about that.
Bernd.
#include <iostream>
#include <CGAL/Homogeneous.h>
#include <CGAL/Gmpzf.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/Polytope_distance_d.h>
#include <CGAL/Polytope_distance_d_traits_2.h>
typedef CGAL::Homogeneous<double> Kernel;
typedef CGAL::Polytope_distance_d_traits_2<Kernel, CGAL::Gmpzf, double>
TraitsPolytope;
typedef CGAL::Polytope_distance_d<TraitsPolytope> Polytope_distance;
typedef Kernel::Point_2 Point_2;
typedef CGAL::Polygon_2<Kernel> Polygon_2;
int main() {
Polygon_2 p;
p.push_back(Point_2(444,607));
p.push_back(Point_2(445,97));
p.push_back(Point_2(448,92));
p.push_back(Point_2(449,610));
Polygon_2 p1;
p1.push_back(Point_2(212,91));
p1.push_back(Point_2(448,92));
p1.push_back(Point_2(445,97));
p1.push_back(Point_2(213,96));
Polytope_distance dist2
(p.vertices_begin(),
p.vertices_end(),
p1.vertices_begin(),
p1.vertices_end());
std::cout<< "dist : "
<< CGAL::to_double(dist2.squared_distance_numerator())/
CGAL::to_double(dist2.squared_distance_denominator())
<<std::endl;
return 0;
