cgal-discuss - Problem with point collinearity
  • To:
  • Subject: Problem with point collinearity
  • Date: Fri, 15 Jun 2007 00:50:43 +0200
Hi all,
This should be a very easy question.
When I check if the points (0.14, 0.22), (0.15, 0.21) and (0.19,0.17) are
collinear, using CGAL::collinear, it returns “CGAL_LEFT”, which is false,
because those points are in fact collinear.
However, if I do the same with the points (14, 22), (15, 21) and (19, 17) I
get the correct answer: “CGAL_COLLINEAR”.
My code is:
#include "bso_rational_nt.h"
#include <CGAL/Cartesian.h>
#include <CGAL/predicates_on_points_2.h>
//#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include<stdio.h>
//typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
//typedef Kernel::Point_2 Point;
typedef CGAL::Cartesian<Number_type> K;
typedef CGAL::Point_2<K> Point;
int main()
//line y=-x+36
switch (CGAL::orientation(Point(14,22),Point(15,21),Point(19,17))){
case CGAL::LEFT_TURN:
std::cout << "Left" << std::endl;
break;
case CGAL::RIGHT_TURN:
std::cout << "Right" << std::endl;
break;
case CGAL::COLLINEAR:
std::cout << "Collinear" << std::endl;
break;
//line y=-x+0.36
switch
(CGAL::orientation(Point(0.14,0.22),Point(0.15,0.21),Point(0.19,0.17))){
break;
break;
break;
(The <bso_rational_nt.h> is the file that is in the folder "C:\Program
Files\CGAL-3.2.1\examples\Boolean_set_operations_2".)
I already tried to use the CGAL::Exact_predicates_exact_constructions_kernel
(as you can check above), but the problem remains.
This problem, in fact, happens with other points, however this is a simple
example.
Anyone have any ideia of what is wrong??
I am using CGAL 3.2.1 and Microsoft Visual Studio 2005.
I really don’t know what is happening. Anyone can help me?
Thanks,
Mafalda
