- To:
- Subject: Newbie questions concerning Delaunay_triangulation_3
- Date: Thu, 14 Jun 2007 14:16:09 -0400 (EDT)
Dear List,
I have recently downloaded and installed CGAL and have run into a minor problem. When I run the attached code, the finite cells include the point (0.5,0.5,0.5), which I have not entered. I only want a delaunay triangulation of the points I have entered. I have tried to remove that point, which corresponds to vertices_begin(), but that results in an exception.
Secondly, is there a structure or method that allows me access to the list of cells of which a given vertex is a member? The documentation of cell() for a vertex has suggested no obvious way to me.
Christopher
PS: Is there a complete class hierarchy diagram for CGAL in the documentation? I haven't come across one so far.
C. Rinderspacher, Ph. D.
Duke University
Dept. of Chemistry
Box 97
Durham, NC 27705
Tel.: (919) 660-1633
E-Mail:
The faults of the burglar are the qualities of the financier.
George Bernard Shaw
#include <iostream> #include <CGAL/basic.h> #include <CGAL/Delaunay_triangulation_3.h> #include <CGAL/Exact_predicates_exact_constructions_kernel.h> #include <CGAL/Point_3.h> typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel; typedef CGAL::Delaunay_triangulation_3<Kernel> Triangulation; typedef Triangulation::Point Point_3; typedef Triangulation::Cell_iterator Cell_iterator; typedef Triangulation::Vertex_iterator Vertex_iterator; //typedef CGAL::Point_3 Point_3; using namespace std; main() { vector<Point_3> L; L.push_back(Point_3(0.0,-0.1200944034,0.0)); L.push_back(Point_3(-1.4301799859,0.9529926662, 0.0000000000 )); L.push_back(Point_3( 1.4301799859,0.9529926662, 0.0000000000 )); L.push_back(Point_3(-1.4301799859,0.9529926662, 1.0000000000 )); L.push_back(Point_3( 1.4301799859,0.9529926662,-1.2000000000 )); L.push_back(Point_3( 1.4301799859,0.9529,-1.000000000 )); Triangulation td(L.begin(),L.end()); Cell_iterator Cell; /* td.insert(Point_3(0.0,-0.1200944034,0.0)); td.insert(Point_3(-1.4301799859,0.9529926662, 0.0000000000 )); td.insert(Point_3( 1.4301799859,0.9529926662, 0.0000000000 )); td.insert(Point_3(-1.4301799859,0.9529926662, 1.0000000000 )); td.insert(Point_3( 1.4301799859,0.9529926662,-1.2000000000 ));*/ Vertex_iterator Vertex=td.vertices_begin(); // td.remove(td.vertex(1)); Vertex=td.finite_vertices_begin(); int k=0; while(Vertex != td.vertices_end()) { cout << " Vertex : " << k++ << endl; cout << "X : " << Vertex->point().x() <<" Y : " << Vertex->point().y() <<" Z : " << Vertex->point().z() << endl; Cell=Vertex->cell(); // td.index(Cell); Vertex++; } int noc=td.number_of_finite_cells(); cout << "\n Number of cells : " << noc; cout << "\n Number of facets : " << td.number_of_finite_facets(); cout << "\n Number of edges : " << td.number_of_finite_edges(); cout << "\n Number of vertices : " << td.number_of_vertices() << endl; Cell=td.finite_cells_begin(); for(int i=0;i<noc;i++, Cell++) { cout << "Cell " << i << " : \n"; for(int j=0;j<4;j++) cout << "X : " << Cell->vertex(j)->point().x() << " Y : " << Cell->vertex(j)->point().y() << " Z : " << Cell->vertex(j)->point().z() << endl; } }
- Begginer in problems, iarbe, 06/13/2007
- Re: [cgal-discuss] Begginer in problems, Andreas Fabri, 06/13/2007
- Question about Convex_hull_d, dmyan, 06/14/2007
- Re: [cgal-discuss] Question about Convex_hull_d, dmyan, 06/14/2007
- Re: [cgal-discuss] Begginer in problems, Iosu Arbe, 06/14/2007
- Polygon operations, Robert Bryce, 06/14/2007
- Re: [cgal-discuss] Polygon operations, Efi Fogel, 06/18/2007
- Delaunay Questions, Robert Bryce, 06/14/2007
- Re: [cgal-discuss] Delaunay Questions, Sylvain Pion, 06/14/2007
- Newbie questions concerning Delaunay_triangulation_3, c . rinders, 06/15/2007
- Re: [cgal-discuss] Newbie questions concerning Delaunay_triangulation_3, Laurent Rineau, 06/15/2007
- Re: [cgal-discuss] Newbie questions concerning Delaunay_triangulation_3, Andreas Fabri, 06/15/2007
- Re: [cgal-discuss] Delaunay Questions, Olivier Devillers, 06/15/2007
- Question about Convex_hull_d, dmyan, 06/15/2007
- Re: [cgal-discuss] Question about Convex_hull_d, Sylvain Pion, 06/15/2007
- Re: [cgal-discuss] Question about Convex_hull_d, dmyan, 06/15/2007
- Re: [cgal-discuss] Question about Convex_hull_d, Bernd Gaertner, 06/15/2007
