cgal-discuss - Re: [cgal-discuss] Question about Convex_hull_d
  • To: <>
  • Subject: Re: [cgal-discuss] Question about Convex_hull_d
  • Date: Fri, 15 Jun 2007 21:28:11 +0800
Dear Bernd,
I am sorry I didn't explain it clearly.
My problem is that I want the sequence of vertices of a facet are same. For example in 3D, the 3 vertices of a facet are either CCW or CW.
Best
dmyan
----- Original Message ----- From: "Bernd Gaertner" <>
To:
Sent: Friday, June 15, 2007 8:42 PM
dmyan wrote:
Dear Bernd,
Thanks for your answer!
But actually, I need to use the signed volume of each simplex in my application. So the sequence of points are required.
Is there any other way to solve this problem?
Then I didn't understand what "this problem" exactly is. Initially, you
wrote that you want to find the volume of a convex hull, and for this, I
don't see how the signed volumes are necessary.
Bernd.
