- To:
- Subject: Re: [cgal-discuss] convex partition with hole
- Date: Mon, 18 Jun 2007 01:17:49 +0200
wrote:
i am trying to useWhat do you mean? The input of the function consists of a single range.
CGAL::approx_convex_partition_2()
with a 2D polygon with an hole
withouth hole no problems, but
with an hole partition is correct
but fill only partialy the polygon
I have used COUNTER_CLOCKWISE for external boundary
and CLOCK_WISE for internal boundary. No intersection
Is this function compatible with polygon with holes ?Quoting from the manual of CGAL::approx_convex_partition_2: "Points in the range /[first, beyond)/ must define a simple polygon whose vertices are oriented counterclockwise."
You can try to use CGAL::connect_holes(pwh) to create a sequence of points that define a single non (strictly) simple polygon, and feed it to
a decomposition function. Notice that if the input polygon of connect_holes() has one hole or more, the output polygon is not strictly simple, as its boundary contains overlapping segments, but there are no self intersections.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- convex partition with hole, asmprog32, 06/17/2007
- Re: [cgal-discuss] convex partition with hole, Efi Fogel, 06/18/2007
- <Possible follow-up(s)>
- Re: convex partition with hole, asmprog32, 06/17/2007
