- To:
- Subject: Re: [cgal-discuss] Polygon operations
- Date: Mon, 18 Jun 2007 02:03:07 +0200
Robert Bryce wrote:
An input polygon must be strictly simple and its vertices must be oriented counterclockwise.
Hi all,
I’m looking at the polygon set operations (union, intersection, difference).
How does CGAL handle self-intersecting polygons in these operations?
Thanks,
--Rob
An input polygon with holes is represented by at most one simple polygon oriented counterclockwise that defines the outer boundary of the polygon, and for each hole a strictly simple polygon, whose vertices are oriented clockwise around the interior of the hole.
A finite number of vertices on the outer boundary of a polygon with holes may appear more than once, but self intersections or overlapping are not allowed.
The General_polygon_set_2 class has an un-documented experimental member function that simplifies an input polygon and converts it into a valid polygon with holes.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- Begginer in problems, iarbe, 06/13/2007
- Re: [cgal-discuss] Begginer in problems, Andreas Fabri, 06/13/2007
- Question about Convex_hull_d, dmyan, 06/14/2007
- Re: [cgal-discuss] Question about Convex_hull_d, dmyan, 06/14/2007
- Re: [cgal-discuss] Begginer in problems, Iosu Arbe, 06/14/2007
- Polygon operations, Robert Bryce, 06/14/2007
- Re: [cgal-discuss] Polygon operations, Efi Fogel, 06/18/2007
- Delaunay Questions, Robert Bryce, 06/14/2007
- Re: [cgal-discuss] Delaunay Questions, Sylvain Pion, 06/14/2007
- Newbie questions concerning Delaunay_triangulation_3, c . rinders, 06/15/2007
- Re: [cgal-discuss] Newbie questions concerning Delaunay_triangulation_3, Laurent Rineau, 06/15/2007
- Re: [cgal-discuss] Newbie questions concerning Delaunay_triangulation_3, Andreas Fabri, 06/15/2007
- Re: [cgal-discuss] Delaunay Questions, Olivier Devillers, 06/15/2007
- Question about Convex_hull_d, dmyan, 06/15/2007
- Re: [cgal-discuss] Question about Convex_hull_d, Sylvain Pion, 06/15/2007
- Re: [cgal-discuss] Question about Convex_hull_d, dmyan, 06/15/2007
- Re: [cgal-discuss] Question about Convex_hull_d, Bernd Gaertner, 06/15/2007
