- To:
- Subject: Re: [cgal-discuss] Re: Triangle comparaison
- Date: Wed, 20 Jun 2007 11:08:23 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=GsLGiOqtRvXDmX+KznQp1UK/dsfhDmolGbw+iiIBo5Wd1pOuegkxb1iCTz8hF00cm6Ph3lFL5Jo68/i0st70mbFik4MUbGrX+sqvoPGqqhio4bwhSHmUIcHLdsEca15XIUbqJMjpy7gQbWvqtDhry2r8gL6n5O0BllssnnRO6fg=
It's from : http://www.cgal.org/Manual/3.3 /doc_html/cgal_manual/Mesh_2_ref/Concept_DelaunayMeshFaceBase_ 2.html#Cross_link_anchor_1060
Thanks for the other idea...
Tyv
2007/6/20, Andreas Fabri <>:
> Hello,
> No idea where the set_in_domain method comes from, but you
> might have a look at the section entitles Flexibility in
> the user manual of the triangulation package
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_25.11
> It explains you and gives you example code for adding
> information to vertices and faces.
> andreas
> Tyver Ray wrote:
> > I've tried your relevant idea but I can't access the set_in_domain
> > method...
> > I coded as below:
> > Line_face_circulator lfc = dt.line_walk(start, end), done(lfc);
> > if (lfc != (CGAL_NULL_TYPE) NULL)
> > do
> > if( !dt.is_infinite(lfc) )
> > ((Tds::Face_base)lfc) -> set_in_domain(false);
> > while (++lfc != done);
> > Thanks for your advice!
> > Tyv
> > 2007/6/19, Laurent Rineau <>:
> >> On Tuesday 19 June 2007 05:45:31 pm Tyver Ray wrote:
> >> > To be clear, my face_circulator is from the same delaunay dt.
> >> > I want to scan only the triangles of dt which aren't in my
> >> face_circulator.
> >> Use a face base with a special boolean.
> >> Travel through the face_circulator, and use that special boolean to
> >> mark faces
> >> that are in the face_circulator.
> >> Then you can scan all faces of the triangulation, and filter those how
> >> have
> >> the marker.
> >> Laurent Rineau
> >> INRIA - Sophia Antipolis
> >> BP 93, 2004 Route des Lucioles
> >> 06902 Sophia Antipolis Cedex FRANCE
> >> You are currently subscribed to cgal-discuss.
> >> To unsubscribe or access the archives, go to
> >> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Triangle comparaison, Tyver Ray, 06/19/2007
- Re: Triangle comparaison, Tyver Ray, 06/19/2007
- Re: [cgal-discuss] Re: Triangle comparaison, Laurent Rineau, 06/19/2007
- Re: [cgal-discuss] Re: Triangle comparaison, Tyver Ray, 06/20/2007
- Re: [cgal-discuss] Re: Triangle comparaison, Andreas Fabri, 06/20/2007
