cgal-discuss - Re: [cgal-discuss] Re: Triangle comparaison
  • To:
  • Subject: Re: [cgal-discuss] Re: Triangle comparaison
  • Date: Wed, 20 Jun 2007 11:20:05 +0200
ok. At least it proves that you read the manual, which I almost
had recommended violently in my previous mail ==:>-
andreas
Tyver Ray wrote:
It's from : http://www.cgal.org/Manual/3.3 <http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Mesh_2_ref/Concept_DelaunayMeshFaceBase_2.html#Cross_link_anchor_1060> /doc_html/cgal_manual/Mesh_2_re <http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Mesh_2_ref/Concept_DelaunayMeshFaceBase_2.html#Cross_link_anchor_1060>f/Concept_DelaunayMeshFaceBase_ <http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Mesh_2_ref/Concept_DelaunayMeshFaceBase_2.html#Cross_link_anchor_1060> 2.html#Cross_link_anchor_1060 <http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Mesh_2_ref/Concept_DelaunayMeshFaceBase_2.html#Cross_link_anchor_1060>
Thanks for the other idea...
Tyv
2007/6/20, Andreas Fabri < <mailto:>>:
> Hello,
> No idea where the set_in_domain method comes from, but you
> might have a look at the section entitles Flexibility in
> the user manual of the triangulation package
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_25.11
> It explains you and gives you example code for adding
> information to vertices and faces.
> andreas
> Tyver Ray wrote:
> > I've tried your relevant idea but I can't access the set_in_domain
> > method...
> > I coded as below:
> > Line_face_circulator lfc = dt.line_walk(start, end), done(lfc);
> > if (lfc != (CGAL_NULL_TYPE) NULL)
> > do
> > if( !dt.is_infinite(lfc) )
> > ((Tds::Face_base)lfc) -> set_in_domain(false);
> > while (++lfc != done);
> > Thanks for your advice!
> > Tyv
> > 2007/6/19, Laurent Rineau < <mailto:>>:
> >> On Tuesday 19 June 2007 05:45:31 pm Tyver Ray wrote:
> >> > To be clear, my face_circulator is from the same delaunay dt.
> >> > I want to scan only the triangles of dt which aren't in my
> >> face_circulator.
> >> Use a face base with a special boolean.
> >> Travel through the face_circulator, and use that special boolean to
> >> mark faces
> >> that are in the face_circulator.
> >> Then you can scan all faces of the triangulation, and filter those how
> >> have
> >> the marker.
> >> Laurent Rineau
> >> INRIA - Sophia Antipolis
> >> BP 93, 2004 Route des Lucioles
> >> 06902 Sophia Antipolis Cedex FRANCE
> >> You are currently subscribed to cgal-discuss.
> >> To unsubscribe or access the archives, go to
> >> https://lists-sop.inria.fr/wws/info/cgal-discuss
> https://lists-sop.inria.fr/wws/info/cgal-discuss <https://lists-sop.inria.fr/wws/info/cgal-discuss>
