cgal-discuss - Re: [cgal-discuss] Bug in Regular Triangulation, CGAL 3.3 (2nd report)
  • To:
  • Subject: Re: [cgal-discuss] Bug in Regular Triangulation, CGAL 3.3 (2nd report)
  • Date: Mon, 25 Jun 2007 22:12:21 +0200
Hi Bernard,
Which compiler.
Does this happen in debug or release mode, or both?
Do you have GMP installed?
andreas
Bernhard Kornberger wrote:
I have reported a bug in the regular triangulation of CGAL 3.3 on
friday. But now I have found an easier example to show the behavior,
it is one of the examples that come with CGAL:
#include <CGAL/Regular_triangulation_euclidean_traits_2.h>
#include <CGAL/Regular_triangulation_filtered_traits_2.h>
#include <CGAL/Regular_triangulation_2.h>
#include <fstream>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Regular_triangulation_filtered_traits_2<K> Traits;
typedef CGAL::Regular_triangulation_2<Traits> Regular_triangulation;
int main()
Regular_triangulation rt;
std::ifstream in("data/regular.cin");
Regular_triangulation::Weighted_point wp;
int count = 0;
while(in >> wp){
count++;
rt.insert(wp);
rt.is_valid();
std::cout << "number of inserted points : " << count << std::endl;
std::cout << "number of vertices : " ;
std::cout << rt.number_of_vertices() << std::endl;
std::cout << "number of hidden vertices : " ;
std::cout << rt.number_of_hidden_vertices() << std::endl;
return 0;
..where I work with this input data:
cat data/regular.cin
62.5 55 1563.24553641
93.9083 55 965.655625
123.495 26.5053 760.67294809
124.307 25.6932 716.53653124
124.819 25.1811 689.38278721
112.5 48.6286 1488.030625
112.5 47.2573 1488.030625
112.5 45.8859 1488.030625
112.5 50 1488.030625
112.5 55 1563.24553641
The original code works. But if one changes the Kernel to
typedef CGAL::Exact_predicates_exact_constructions_kernel K;
then the software crashes:
./regular
CGAL error: assertion violation!
Expr: !(i>s)
File: ../../include/CGAL/Interval_nt.h
Line: 77
Explanation: Variable used before being initialized (or CGAL bug)
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: !(i>s)
Line: 77
Aborted (core dumped)
Shouldn't it also work with the exact kernel? What can I do?
Best
Bernhard
