cgal-discuss - Re: [cgal-discuss] Bug in Regular Triangulation, CGAL 3.3 (2nd report)
  • To:
  • Subject: Re: [cgal-discuss] Bug in Regular Triangulation, CGAL 3.3 (2nd report)
  • Date: Thu, 28 Jun 2007 18:49:48 +0200 (CEST)
  • Importance: Normal
Le Jeu 28 juin 2007 0:04, Bernhard Kornberger a écrit :
>> The problem pops up only with the exact constructions kernel because it
>> is the one which detects uninitialized data. The reason why one of the
> ..but I had also an input file where the original example that uses
> inexact constructions ("examples/Triangulation_2/regular.cpp") had
> a segfault. However, it seems to be also repaired now.
I was not speaking for the general case: you had some deleted faces with
deleted vertices hanging around in a list and being accessed. This caused
a problem with the interval arithmetic immediately, because a non
initialized value would be detected. Of course, even if the arithmetic
does not crash, you have a fair chance of triggering a segfault because of
the inconsistent data. You were lucky enough to avoid it in this case...
Best,
Camille
