- To:
- Subject: Re: [cgal-discuss] Problem with Line_walk
- Date: Fri, 29 Jun 2007 21:31:04 +0200
Hi Tyver,
You cannot permute them in the triangulation itself. I mean maybe
you can, but this doesn't really make sense.
What you know is that vertex(i) is followed in counterclockwise order
by vertex((i+1) % 3
best regards,
andreas
Tyver Ray wrote:
Thanks Andreas, but do CGAL provides a function to permute the vertices of a triangle without changing the Delaunay construction?
2007/6/29, Patrick Hétroy <
<mailto:>>:
Ok so Tyver should permute manually the vertices of the triangles ?
2007/6/28, Andreas Fabri <
<mailto:>>:
The face doesn't know that you walk from top to bottom.
Imagine if at the bottom left was a triangle like this
u**
* f *
v w
and you first walk down, and then from left to right along
the lower edge. You can't expect that f->vertex(0) is once u
and the next time v, only because you do another walk.
The vertices can be in a cyclic permutation, they are always
in counterclockwise order, so that the interior is to the left.
andreas
Patrick Hétroy wrote:
> I don't have any idea to resolve your problem but I think that :
> The Delaunay triangulation doesn't care about the order of
point insertion.
> But, the function line_walk depends on the order of the
insertion...
> If you can change your points order :p ^^
> Patrick
> 2007/6/28, Tyver Ray <
<mailto:>
<mailto:
<mailto:>>>:
> ---------- Forwarded message ----------
> From: *Tyver Ray* <
<mailto:>
<mailto:
<mailto:>>>
> Date: 28 juin 2007 10:22
> Subject: Problem with Line_walk
> To:
<mailto:>
> <mailto:
<mailto:>>
> Hello!
> I'm trying to get all the vertices on the left side of my
square
> surface with line_walk but it seems to be a problem...
> I use Delaunay transformation with these points :
> int step = 25;
> dt.insert(Point3(0*step, 0, 3));
> dt.insert(Point3(1*step, 0, 6));
> dt.insert (Point3(2*step, 0, 13));
> dt.insert(Point3(3*step, 0, 9));
> dt.insert(Point3(4*step, 0, 6));
> dt.insert(Point3(0*step, 1*step, 3));
> dt.insert(Point3(1*step, 1*step, 7));
> dt.insert(Point3(2*step, 1*step, 8));
> dt.insert(Point3(4*step, 2*step, 8));
> dt.insert(Point3(0*step, 3*step, 13));
> dt.insert(Point3(1*step, 3*step, 17));
> dt.insert(Point3(2*step, 3*step, 13));
> dt.insert(Point3(3*step, 3*step, 18));
> dt.insert(Point3(4*step, 3*step, 18));
> dt.insert(Point3(0*step, 4*step, 13));
> dt.insert(Point3(1*step, 4*step, 7));
> dt.insert(Point3(2*step, 4*step, 3));
> dt.insert(Point3(3*step, 4*step, 1));
> dt.insert(Point3(4*step, 4*step, 1));
> dt.insert (Point3(12.5, 12.25, 7));
> dt.insert(Point3(62.5, 12.25, 7));
> dt.insert(Point3(90, 25, 1));
> dt.insert(Point3(87.5, 87.5, 1));
> After I use the line_walk function to get the vertices
which are in
> the up to down direction of my squre surface with:
> (the bottom left of the squre is the point (0, 0) and the
up right
> is (100, 100))
> const Point3& start = Point3(0, 100, 0);
> const Point3& end = Point3(0, 0, 0);
> Line_face_circulator lfc = dt.line_walk(start, end),
done(lfc);
> if (lfc != (CGAL_NULL_TYPE) NULL)
> do
> //Show the coordinates of all triangles on he
left sife
> of my square
> if( !dt.is_infinite(lfc) )
> showCoordinates(lfc, 0);
> showCoordinates(lfc, 1);
> showCoordinates(lfc, 2);
> while (++lfc != done);
> The result are :
> //Triangle 1
> Vertex Point : 0
> x: 25
> y: 75
> z: 17
> Vertex Point : 1
> x: 0
> y: 100
> z: 13
> Vertex Point : 2
> x: 0
> y: 75
> z: 13
> //Triangle 2
> Vertex Point : 0
> x: 25
> y: 25
> z: 7
> Vertex Point : 1
> x: 0
> y: 75
> z: 13
> Vertex Point : 2
> x: 0
> y: 25
> z: 3
> //Triangle 3
> Vertex Point : 0
> x: 0
> y: 0
> z: 3
> Vertex Point : 1
> x: 12.5
> y: 12.25
> z: 7
> Vertex Point : 2
> x: 0
> y: 25
> z: 3
> The triangle 3 has not the same count of the vertices. It
doesn't
> display first the vertex opposed to the edge which is on the
> direction up to down as the Triangle 1 and 2.
> I would like the same order of display for each point.
> How can I fix the problem?
<https://lists-sop.inria.fr/wws/info/cgal-discuss>
- Problem with Line_walk, Tyver Ray, 06/28/2007
- Re: [cgal-discuss] Problem with Line_walk, Patrick Hétroy, 06/28/2007
- Re: [cgal-discuss] Problem with Line_walk, Andreas Fabri, 06/28/2007
- Re: [cgal-discuss] Problem with Line_walk, Patrick Hétroy, 06/29/2007
- Re: [cgal-discuss] Problem with Line_walk, Tyver Ray, 06/29/2007
- Re: [cgal-discuss] Problem with Line_walk, Andreas Fabri, 06/29/2007
