- To: <>
- Subject: Straight Skeleton bug?
- Date: Tue, 10 Jul 2007 12:08:38 -0400
- Importance: Normal
Hi,
I am using the straight skeleton algorithm to expand a polygon. I think I have encountered a bug in the algorithm.
I have modified the Straight Skeleton example given (Straight_skeleton_2.cpp) and get back a result that I am sure it is wrong. See the attached picture. In this picture, I am trying to expand the red polygon in the middle by 700nm (0.7 um) and I get back the yellow polygon highlighted in the end.
FYI, the coordinates red polygon are given by:
Point_2 pts[] = {
Point_2(161930,83115),
Point_2(162035,83115),
Point_2(162035,83010),
Point_2(162050,83010),
Point_2(162050,82505),
Point_2(162135,82420),
Point_2(162135,81485),
Point_2(162250,81485),
Point_2(162250,82475),
Point_2(162165,82560),
Point_2(162165,83010),
Point_2(162185,83010),
Point_2(162185,83115),
Point_2(162250,83115),
Point_2(162250,83335),
Point_2(162180,83335),
Point_2(162180,83785),
Point_2(162245,83850),
Point_2(162245,84565),
Point_2(162130,84565),
Point_2(162130,83905),
Point_2(162065,83840),
Point_2(162065,83335),
Point_2(161930,83335)
The result that I got in the end is:
161230 84035
161230 82415
161335 82415
161335 82310
161350 82310
161350 82215.1
161435 82130.1
161435 80785
162950 80785
162950 82764.9
offset used is 700.
It seems that for some reason, half of the expanded polgyon is gone.
I tried both exact and inexact kernel and it gives back the same result.
Compiler and platform is: x86-64_Linux-2.6_g++-3.4.6
Thanks a lot for your help and have a nice day.
Best,
Jason
See what you’re getting into…before you go there. Check it out!
Description: image/pjpeg
- Straight Skeleton bug?, Tam WingChiu, 07/10/2007
- Re: [cgal-discuss] Straight Skeleton bug?, Fernando Cacciola, 07/10/2007
