Re: [cgal-discuss] Triangulation_vertex_base_with_info_3 and Regular_triangulation_3 gives compile error on T.insert()
- To:
- Subject: Re: [cgal-discuss] Triangulation_vertex_base_with_info_3 and Regular_triangulation_3 gives compile error on T.insert()
- Date: Tue, 10 Jul 2007 19:49:29 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Tuesday 10 July 2007 19:10:17 Thomas Zangl - Home wrote:
> You mean like this:
> typedef CGAL::Triangulation_vertex_base_with_info_3<CGAL::Color, K> Vb;
> typedef CGAL::Regular_triangulation_cell_base_3<K> Cb;
> typedef CGAL::Triangulation_data_structure_3<Vb, Cb> Tds;
> typedef CGAL::Regular_triangulation_filtered_traits_3<K>
> Regular_TriangulationTraits; typedef
> CGAL::Regular_triangulation_3<Regular_TriangulationTraits, Tds>
> Regular_triangulation;
Well, I am not sure, but I would try:
typedef CGAL::Regular_triangulation_filtered_traits_3<K> Traits;
typedef CGAL::Triangulation_vertex_base_with_info_3<CGAL::Color, Traits> Vb;
typedef CGAL::Regular_triangulation_cell_base_3<Traits> Cb;
So that the traits class passed in Vb and Cb is the right traits class.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
- Triangulation_vertex_base_with_info_3 and Regular_triangulation_3 gives compile error on T.insert(), Thomas Zangl - Home, 07/10/2007
- Re: [cgal-discuss] Triangulation_vertex_base_with_info_3 and Regular_triangulation_3 gives compile error on T.insert(), Laurent Rineau, 07/10/2007
- Re:[cgal-discuss] Triangulation_vertex_base_with_info_3 and Regular_triangulation_3 gives compile error on T.insert(), Thomas Zangl - Home, 07/10/2007
