- To: <>
- Subject: RE: [cgal-discuss] Straight Skeleton bug?
- Date: Tue, 10 Jul 2007 14:46:19 -0400
- Importance: Normal
Thank you so much!! :-)
best,
Jason Tam
> From:
> To:
> Date: Tue, 10 Jul 2007 15:30:45 -0300
> Subject: Re: [cgal-discuss] Straight Skeleton bug?
> Hello Tam,
> I've been precisely working on a bug fix for the Straigt Skeleton package.
> The fix is ready on my PC but I'm still testing it exaustively to make sure
> nothing else breaks.
> FWIW, your example works fine for me. See the attached picture obtained
> using the demo.
> Soon there will be a bug fix release for CGAL in which this fix will be
> incorporated.
> Best
> Fernando Cacciola
> GeometryFactory
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
See what you’re getting into…before you go there. Check it out!
- RE: [cgal-discuss] Straight Skeleton bug?, Tam WingChiu, 07/10/2007
