cgal-discuss - Re: Re:[cgal-discuss] Location of point relative to polyhedron
  • To:
  • Subject: Re: Re:[cgal-discuss] Location of point relative to polyhedron
  • Date: Fri, 20 Jul 2007 11:10:57 +0200
It seems that the Exact_predicates_exact_constructions_kernel uses
MP_float is number type if GMP is not installed and that MP_float has no
division operation, which is needed by Nef polyhedra. You could install
GMP or switch to a different Kernel. The first option is preferable.
Peter
On Thu, 2007-07-19 at 18:32 +0200, Thomas Zangl - Home wrote:
> Am Thu, 19 Jul 2007 11:57:20 +0200, schrieb "Peter Hachenberger"
> Hi!
> >A Nef_polyhedron is a decomposition of the 3-space into
> >vertices, edges, facets, and volumes. That means, the outer volume is
> >also modeled as a volume. You can distinguish the inner and outer volume
> >by its mark.
> >Volume_handle c;
> >Object_handle o;
> >o = myNef.locate(Point_3(5,3,2));
> >if(assign(c, o))
> > if(c->mark())
> > std::cerr << "found inner volume" << std::endl;
> > else
> > std::cerr << "found outer volume" << std::endl;
> Thanks!
> I now have an issue with the Nef_Polyhedron. My typedefs:
> typedef CGAL::Exact_predicates_exact_constructions_kernel K;
> typedef CGAL::Nef_polyhedron_3<K> Nef_polyhedron;
> typedef Nef_polyhedron::Object_handle Nef_object_handle;
> typedef Nef_polyhedron::Volume_const_handle Nef_volume_handle;
> I then added a member "pNef_" of type Nef_Polyhedron to my class:
> class MyClass {
> private:
> std::string name_;
> Polyhedron p_;
> Nef_polyhedron pNef_;
> and my compiler complains:
> /home/TZi/CGAL-3.3/include/CGAL/Lazy_exact_nt.h: In member function `void
> CGAL::Lazy_exact_Div<ET, ET1, ET2>::update_exact() [with ET =
> CGAL::MP_Float, ET1 = CGAL::MP_Float, ET2 = CGAL::MP_Float]':
> src/myClass.cpp:123: instantiated from here
> /home/TZi/CGAL-3.3/include/CGAL/Lazy_exact_nt.h:325: error: no match for
> 'operator/' in '((CGAL::Lazy<CGAL::Interval_nt< false>, CGAL::MP_Float,
> CGAL::Lazy_exact_nt<CGAL::MP_Float>, CGAL::To_interval<CGAL::MP_Float>
> >*)(((CGAL::Lazy_exact_nt<CGAL::MP_Float>*)((CGAL::Lazy_exact_binary<CGAL::MP_Float,
> CGAL::MP_Float, CGAL::MP_Float>*)((CGAL::Lazy_exact_Div<CGAL::MP_Float,
> CGAL::MP_Float, CGAL::MP_Float>*)this))) + 28u))->CGAL::Lazy<AT, ET, EFT,
> E2A>::exact [with AT_ = CGAL::Interval_nt< false>, ET_ = CGAL::MP_Float,
> EFT = CGAL::Lazy_exact_nt<CGAL::MP_Float>, E2A =
> CGAL::To_interval<CGAL::MP_Float>]() / ((CGAL::Lazy<CGAL::Interval_nt<
> false>, CGAL::MP_Float, CGAL::Lazy_exact_nt<CGAL::MP_Float>,
> CGAL::MP_Float, CGAL::MP_Float>*)this))) + 36u))->CGAL::Lazy<AT, ET, EFT,
> E2A>::exact [with AT_!
> CGAL::Interval_nt< false>, ET_ = CGAL::MP_Float, EFT =
> CGAL::To_interval<CGAL::MP_Float>]()'
> make: *** [src/myClass.o] Error 1
> Whats that...?
> Best regards,
> ,yours Thomas Zangl, Bakk.rer.soc.oec. -
> - Freelancer - IT Consulting & Software Development -
> - Student of Software Development-Economy (Master) -
