- To: <>
- Subject: error in polyhedron_self_intersection.cpp?
- Date: Fri, 20 Jul 2007 10:51:07 +0200
typedef
CGAL::Bbox_3 Bbox;typedef
CGAL::Exact_predicates_inexact_constructions_kernel Kernel;typedef
Kernel::Triangle_3 Triangle;typedef
Kernel::Segment_3 Segment;typedef
Kernel::Point_3 Point;typedef
CGAL::Polyhedron_3<Kernel> Polyhedron;typedef
Polyhedron::Halfedge_const_handle Halfedge_const_handle;typedef
Polyhedron::Facet_const_iterator Facet_const_iterator;typedef
Polyhedron::Facet_const_handle Facet_const_handle;typedef
CGAL::Box_intersection_d::Box_with_handle_d< double, 3, Facet_const_handle> Box;std::vector<Triangle> triangles;
struct
Intersect_facets { void operator()( const Box* b, const Box* c) const {Halfedge_const_handle h = b->handle()->halfedge();
// check for shared egde --> no intersection if ( h->opposite()->facet() == c->handle()|| h->next()->opposite()->facet() == c->handle()
|| h->next()->next()->opposite()->facet() == c->handle())
return; // check for shared vertex --> maybe intersection, maybe notHalfedge_const_handle g = c->handle()->halfedge();
Halfedge_const_handle v;
if ( h->vertex() == g->vertex())v = g;
if ( h->vertex() == g->next()->vertex())v = g->next();
if ( h->vertex() == g->next()->next()->vertex())v = g->next()->next();
if ( v == Halfedge_const_handle()) {h = h->next();
if ( v != Halfedge_const_handle()) { // found shared vertex:CGAL_assertion( h->vertex() == v->vertex());
// geomtric check if the opposite segments intersect the trianglesTriangle t1( h->vertex()->point(),
h->next()->vertex()->point(),
h->next()->next()->vertex()->point());
Triangle t2( v->vertex()->point(),
v->next()->vertex()->point(),
v->next()->next()->vertex()->point());
Segment s1( h->next()->vertex()->point(),
Segment s2( v->next()->vertex()->point(),
if ( CGAL::do_intersect( t1, s2)) { //cerr << "Triangles intersect (t1,s2):\n T1: " << t1 // << "\n T2 :" << t2 << endl;triangles.push_back(t1);
triangles.push_back(t2);
else if ( CGAL::do_intersect( t2, s1)) { //cerr << "Triangles intersect (t2,s1):\n T1: " << t1 // << "\n T2 :" << t2 << endl;triangles.push_back(t1);
return;}
// check for geometric intersectionTriangle t1( h->vertex()->point(),
Triangle t2( g->vertex()->point(),
g->next()->vertex()->point(),
g->next()->next()->vertex()->point());
if ( CGAL::do_intersect( t1, t2)) { //cerr << "Triangles intersect:\n T1: " << t1 << "\n T2 :" // << t2 << endl;
cerr <<
"triangles intersect: " << endl;triangles.push_back(t1);
void
write_off() {cout <<
"OFF\n" << ( triangles.size( ) * 3 ) << ' ' << triangles.size( )<<
" 0\n"; for ( std::vector<Triangle>::iterator i = triangles.begin(); i != triangles.end(); ++i) {cout << i->vertex( 0 ) <<
'\n';cout << i->vertex( 1 ) <<
'\n';cout << i->vertex( 2 ) <<
'\n';}
for ( std::size_t k = 0; k != triangles.size(); ++k) {cout <<
"3 " << ( 3 * k ) << ' ' << ( 3 * k+1 ) << ' ' << ( 3 * k + 2 ) << '\n';}
void
intersection( const Polyhedron& P) {std::vector<Box> boxes;
boxes.reserve( P.size_of_facets());
for ( Facet_const_iterator i = P.facets_begin(); i != P.facets_end(); ++i){boxes.push_back(
Box( i->halfedge()->vertex()->point().bbox()
+ i->halfedge()->next()->vertex()->point().bbox()
+ i->halfedge()->next()->next()->vertex()->point().bbox(),
i));
std::vector<
const Box*> box_ptr;box_ptr.reserve( P.size_of_facets());
for ( std::vector<Box>::iterator j = boxes.begin(); j != boxes.end(); ++j){box_ptr.push_back( &*j);
CGAL::box_self_intersection_d( box_ptr.begin(), box_ptr.end(), Intersect_facets(), std::ptrdiff_t(2000));
int
main() {Polyhedron P;
const char* name = "cin";istream* p_in1 = &cin;
ifstream in1;
char par[ 10 ];CGAL::Timer user_time;
cerr <<
"Loading OFF file ... " << endl;user_time.start();
in1.open(
".\\esferas.off");p_in1 = &in1;
(*p_in1) >> P;
cerr <<
"Loading OFF file : " << user_time.time() << " seconds." << endl; if ( ! P.is_pure_triangle()) {cerr <<
"The input object is not triangulated. Cannot intersect."<< endl;
exit(1);
user_time.reset();
cerr <<
"Intersection ... " << endl;intersection( P );
cerr <<
"Intersection : " << user_time.time() << " seconds." << endl;write_off();
scanf(
" %s ", par ); return 0;}
esferas.off
Description: Binary data
- error in polyhedron_self_intersection.cpp?, Isabel, 07/20/2007
- Re: [cgal-discuss] error in polyhedron_self_intersection.cpp?, Matthijs Sypkens Smit, 07/20/2007
- RE: [cgal-discuss] error in polyhedron_self_intersection.cpp?, Isabel, 07/23/2007
