cgal-discuss - known issue with Nef_polyhedron_3.is_convex() ?
  • To: <>
  • Subject: known issue with Nef_polyhedron_3.is_convex() ?
  • Date: Fri, 20 Jul 2007 12:07:55 +0200
  • Disposition-notification-to: "Zorg" <>
Hi,
I use the example given with CGAL-3.3 "examples/Nef_3/point_set_operations.cpp",
with adding only one line before "return 0;", which line is "CGAL_assertion(Cube2.is_convex());"
Compilation fails with the following message:
g++  -Wall -frounding-math '-I/usr/local/include' -I/usr/include/Qt  -g g++ -ggdb -I/usr/local/include/crystalspace -ggdb -c X2.cc -o X2.o -Wall -frounding-math -DCGAL_USE_CGAL_CORE
/usr/local/include/CGAL/Nef_3/Infimaximal_box.h: In static member function ‘static typename SNC_structure::Volume_handle CGAL::Infimaximal_box<CGAL::Boolean_tag<true>,
Kernel>::getNirvana(SNC_structure&) [with SNC_structure = const
CGAL::SNC_structure<CGAL::Extended_homogeneous<CGAL::Gmpz>, CGAL::SNC_items,
bool>, Kernel = CGAL::Extended_homogeneous<CGAL::Gmpz>]’:
/usr/local/include/CGAL/Nef_polyhedron_3.h:668:   instantiated from ‘bool
CGAL::Nef_polyhedron_3<K, I, Mk>::is_convex() const [with Kernel_ = CGAL::Extended_homogeneous<CGAL::Gmpz>, Items_ = CGAL::SNC_items, Mark_ = bool]’
X2.cc:32:   instantiated from here
/usr/local/include/CGAL/Nef_3/Infimaximal_box.h:362: erreur: conversion from ‘CGAL::CGALi::In_place_list_const_iterator<CGAL::SNC_in_place_list_volume<CGAL::SNC_items::Volume<CGAL::SNC_structure<CGAL::Extended_homogeneous<CGAL::Gmpz>,
CGAL::SNC_items, bool> > >,
std::allocator<CGAL::SNC_in_place_list_volume<CGAL::SNC_items::Volume<CGAL::SNC_structure<CGAL::Extended_homogeneous<CGAL::Gmpz>,
CGAL::SNC_items, bool> > > > >’ to non-scalar type ‘CGAL::CGALi::In_place_list_iterator<CGAL::SNC_in_place_list_volume<CGAL::SNC_items::Volume<CGAL::SNC_structure<CGAL::Extended_homogeneous<CGAL::Gmpz>,
CGAL::SNC_items, bool> > > > >’ requested
make: *** [X2.o] Erreur 1
Is there any known issue with Nef_polyhedron_3.is_convex()?
CGAL is configured as this:
  **                     Compiling CGAL 3.3                     **
  OS:                           i686_Linux-2.6
  COMPILER:                     GNU 4.1.2
  BOOST:                        supported (1.33.1)
  BOOST_PROGRAM_OPTIONS:        supported (1.33.1)
  BOOST_BIMAP:                  not supported
  X11:                          supported (11.0)
  GMP:                          supported (4.1.4)
  GMPXX:                        supported (4.1.4)
  MPFR:                         supported (2.2.1)
  ZLIB:                         supported (1.2.3)
  BLAS:                         not supported
  LAPACK:                       not supported
  ATLAS:                        not supported
  LEDA:                         not supported
  LEDAWIN:                      not supported
  OPENGL:                       supported (2.1)
  QT:                           supported (3.3.8)
  TAUCS:                        not supported
Thanks for help.
