cgal-discuss - Re: [cgal-discuss] Bug in Delaunay Triangulation 3 (fixed, no bug)
  • To:
  • Subject: Re: [cgal-discuss] Bug in Delaunay Triangulation 3 (fixed, no bug)
  • Date: Wed, 08 Aug 2007 19:43:13 +0200
Laurent Rineau schrieb:
Insert here:
typedef CGAL::Triangulation_cell_base_3<K> Cb;
typedef CGAL::Triangulation_data_structure_3<Vbh> Tds;
Here you need to precise Cb:
typedef CGAL::Triangulation_data_structure_3<Vbh, Cb> Tds;
The way you have instanciated your Tds, by precising only the vertex base, you have got the Triangulation_ds_cell_base_3<K> as cell base, which is not a model of the concept TriangulationCellBase_3.
Actually, examples/Triangulation_3/hierarchy.cpp does not follow the documentation requirements either. It works only because it does not class dual().
I thought it was a bug because it worked flawlessly in previous
versions of CGAL. IIRC I have the typedefs from some of the
examples or form the documentation of previous versions.
However, thank you very much, this fixed my problem.
Best regards
Bernhard Kornberger
