- To:
- Subject: Re: [cgal-discuss] Finite Triangle from infinite cell in triangulation
- Date: Wed, 8 Aug 2007 11:44:29 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=U4rs14ttoQgJC+kwxC7awEaDSoIRoyHa0t6dfL2Iw2t1vta62jZ/NZNmVrsnvmoH2sowpw4Szveeu1cSIPlzSF0wpStRfHPqzMGMrzyOwPAudYuSq/w1ymye/sRLCImpL2Wg5f1n2cGHNtFiwRbKWhW4+/4qcviBdsmaaAnqVg4=
Thanks a lot Laurent and Monique.
This step suggested by Laurent finally worked properly. I will also try it out with the convex hull approach to see which one works faster for the data set.
regards,
Satyajit
- Re: [cgal-discuss] Finite Triangle from infinite cell in triangulation, (continued)
- Re: [cgal-discuss] Finite Triangle from infinite cell in triangulation, Laurent Rineau, 08/08/2007
- Re: [cgal-discuss] Finite Triangle from infinite cell in triangulation, Satyajit Sarangi, 08/08/2007
- Re: [cgal-discuss] Finite Triangle from infinite cell in triangulation, Monique . Teillaud, 08/08/2007
- Re: [cgal-discuss] Finite Triangle from infinite cell in triangulation, Sylvain Pion, 08/08/2007
