- To:
- Subject: Re: Re: [cgal-discuss] Polygon Set Symmetric Difference gives wrong results
- Date: Sun, 26 Aug 2007 07:52:43 +0200
Why So? I don't see a reason for the result not being properly divided. Also,
the algorithm creates the vertices on the outer polygon (i.e., splits the
edges of polygon 1 in half), and if polygon 2 remains a hole, this is not
understood by me (although convenient to "patch" the algorithm the way I
need..)
Amir.
- Re: Re: [cgal-discuss] Polygon Set Symmetric Difference gives wrong results, avaxman, 08/26/2007
- Re: [cgal-discuss] Polygon Set Symmetric Difference gives wrong results, Efraim Fogel, 08/26/2007
