- To:
- Subject: Re: [cgal-discuss] Polygon Set Symmetric Difference gives wrong results
- Date: Sun, 26 Aug 2007 10:45:01 +0300
It's a valid representation. There are many valid representations for some given configuration including the one you described. The result though is consistent. For example, if you insert the 4 triangles, which make up the configuration you described, you still get one polygon with a hole.
In some cases you may want to get the 4 triangles and in other you may want to get the one with the hole. You can always process it and get what you need, as you can rely on the output to be consistent.
wrote:
Why So? I don't see a reason for the result not being properly divided. Also, the--
algorithm creates the vertices on the outer polygon (i.e., splits the edges of polygon
1 in half), and if polygon 2 remains a hole, this is not understood by me (although
convenient to "patch" the algorithm the way I need..)
Amir.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- Re: Re: [cgal-discuss] Polygon Set Symmetric Difference gives wrong results, avaxman, 08/26/2007
- Re: [cgal-discuss] Polygon Set Symmetric Difference gives wrong results, Efraim Fogel, 08/26/2007
