- To:
- Subject: Re: [cgal-discuss] Arrangements with history
- Date: Sun, 02 Sep 2007 12:17:53 +0200
Michael George wrote:
Hi,The order of the edges is arbitrary. It is a non-trivial deficiency, which we may fix in the future. You will need to sort them out yourself, or develop your own Arrangement_with_history_2.
I'm using the Arrangements with history, and I can't find any documentation on what order the halfedges associated with a given curve are iterated. If my original curves have an associated orientation is there an easy way to traverse only the induced edges that are co-aligned and ordered from source to target?
Thanks,
Mike
An input geometric curve could be split several times, either in order to split it into x-monotone curves, or at intersection points. The edges induced by an x-monotone curve, which is split at intersection points, can be given a strict order, say left to right. However, the items induced by a (general) curve, cannot be given an order. As a matter of fact, these items could be either edges or (isolated) vertices, as in the case of the following curve (x+y)(x^2 + y^2 - r^2) = 0.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- Arrangements with history, Michael George, 09/01/2007
- Re: [cgal-discuss] Arrangements with history, Efi Fogel, 09/02/2007
