- To:
- Subject: Simple polygonal mesh (height field data)
- Date: Sat, 1 Sep 2007 09:24:32 +0200
Hi,
I understand that CGAL handles 2-Manifold.
I am not very strong in the mathematics of Manifold.
I'd like to find out if the following type of data is suitable for being
represented in CGAL.
I have a set of points (from height fields) which I need to grid up as a 3D
mesh. They are sampled at regular points so will form a regular grid.
I like the idea of being able to find neighbouring points, edges and face
using CGAL and also the subdivision surface-mesh generation.
Can I use CGAL to represent my data points (3D) or should I consider other
approach. If CGAL is not suitable, does anyone have a recommendation of what
package is able to represent simple polygonal mesh which may not be manifold?
Meanwhile, I have downloaded the latest CGAL-3.3 source to have a look on
my OS X box. If CGAL is suitable, which chapter/example should I concentrate
on reading up?
Regards
- Simple polygonal mesh (height field data), yue . nicholas, 09/01/2007
- Re: [cgal-discuss] Simple polygonal mesh (height field data), Bart Janssens, 09/01/2007
- Re: [cgal-discuss] Simple polygonal mesh (height field data), Nicholas Yue, 09/05/2007
