- To:
- Subject: Re: [cgal-discuss] Triangulation_ds_face_base_2.h
- Date: Wed, 05 Sep 2007 14:33:17 +0200
Hello Angelina,
In Thunderbird your mails have two different
strings for the "Sender", and I didn't make
the link between those.
I am not motivated to debug your code.
Can you check that the vertex is really
a vertex of the triangulation, by iterating
over all vertices and comparing, just
before you make the function call where
the assert fails.
andreas
Angelina Novacheva wrote:
Thanks Andreas,
But could not be that as well. I never remove anything
from the triangulation. Also the vertex is valid as
before the line where all hangs I access its ->info()
part.
I uploaded the project yesterday, but here it is once
again.
Thank you,
Angelina
____________________________________________________________________________________
Looking for a deal? Find great prices on flights and hotels with Yahoo!
FareChase.
http://farechase.yahoo.com/-- You are currently subscribed to cgal-discuss.
- Re: Re: [cgal-discuss] Triangulation_ds_face_base_2.h, Angelina Novacheva, 09/04/2007
- <Possible follow-up(s)>
- Re: Re: [cgal-discuss] Triangulation_ds_face_base_2.h, novacheva, 09/04/2007
- Re: [cgal-discuss] Triangulation_ds_face_base_2.h, Andreas Fabri, 09/05/2007
- Re: Re: [cgal-discuss] Triangulation_ds_face_base_2.h, novacheva, 09/05/2007
- Re: [cgal-discuss] Triangulation_ds_face_base_2.h, Angelina Novacheva, 09/05/2007
