- To:
- Subject: Re: [cgal-discuss] 3D Delaunay Triangulation
- Date: Fri, 14 Sep 2007 20:28:01 +0200
Wesley Smith wrote:
Then you will se that entire R^3 gets triangulated which
means that there is one additional tetrahedron per face
of the convex hull that has as fourth vertex the, unique,
infinite vertex.
Thanks for pointing this out. I've been reading through the manual
and reference manual quite thoroughly but haven't found a way to
filter these out. Is there a function such as is_infinite for the
cells? I don't see anything like this. I just need a simple test for
this. Any help is greatly appreciated.
ok, so my rtfm doesn't apply here ==:>-
As we use derivation, much of the functionality of the Delaunay
triangulation is documented in the base class Triangulation_2
Go to section "Refines" and click.
Note that even this class has a further base class.
Some of the documentation is also in the Vertex and Cell class.
Also note that there is a user manual which explains things
and gives examples, and the reference manual which is just the
documentation of the API.
best,
andreas
thanks,
wes
- 3D Delaunay Triangulation, Wesley Smith, 09/14/2007
- Re: [cgal-discuss] 3D Delaunay Triangulation, Andreas Fabri, 09/14/2007
- Re: [cgal-discuss] 3D Delaunay Triangulation, Wesley Smith, 09/14/2007
