cgal-discuss - Re: [cgal-discuss] 3D Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] 3D Delaunay Triangulation
  • Date: Fri, 14 Sep 2007 21:47:16 +0200
Wesley Smith wrote:
So here's a question. If I'm iterating over all of the finite cells
and the reason I'm getting 4 cells instead of 1 for 4 points in a
triangulation_3 is that the convex hull of the triangulation has faces
with cells going to the "fictional" infinite point, then shouldn't
those cells not be accessible via the finite iterator?
I just modified the example file simple.cpp slighlty,
and can't reproduce your finding.
Are you sure to iterator over finite_cells and not over finite_faces,
because for the latter there should be 4.
andreas
#include <CGAL/Triangulation_3.h>
#include <iostream>
#include <fstream>
#include <cassert>
#include <list>
#include <vector>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_3<K> Triangulation;
typedef Triangulation::Cell_handle Cell_handle;
typedef Triangulation::Vertex_handle Vertex_handle;
typedef Triangulation::Locate_type Locate_type;
typedef Triangulation::Point Point;
int main()
// construction from a list of points :
std::list<Point> L;
L.push_front(Point(0,0,0));
L.push_front(Point(1,0,0));
L.push_front(Point(0,1,0));
L.push_front(Point(0,0,1));
Triangulation T(L.begin(), L.end());
for(Triangulation::Finite_cells_iterator it = T.finite_cells_begin();
it != T.finite_cells_end();
++it){
std::cout << "oops" << std::endl;
return 0;
wes
On 9/14/07, Andreas Fabri
wrote:
Wesley Smith wrote:
Then you will se that entire R^3 gets triangulated which
means that there is one additional tetrahedron per face
of the convex hull that has as fourth vertex the, unique,
infinite vertex.
Thanks for pointing this out. I've been reading through the manual
and reference manual quite thoroughly but haven't found a way to
filter these out. Is there a function such as is_infinite for the
cells? I don't see anything like this. I just need a simple test for
this. Any help is greatly appreciated.
ok, so my rtfm doesn't apply here ==:>-
As we use derivation, much of the functionality of the Delaunay
triangulation is documented in the base class Triangulation_2
Go to section "Refines" and click.
Note that even this class has a further base class.
Some of the documentation is also in the Vertex and Cell class.
Also note that there is a user manual which explains things
and gives examples, and the reference manual which is just the
documentation of the API.
best,
andreas
thanks,
wes
