Re: [cgal-discuss] Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h
- To:
- Subject: Re: [cgal-discuss] Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h
- Date: Mon, 17 Sep 2007 08:21:38 +0200
Hi Efraim, Hi Ron,
Thanks for the fast reply and the patch. On my box it seemingly eliminated the bugs, well done.
Kind regards
David Keller
Efraim Fogel wrote:
Hi David,
Ron Wein, has provided a fix. Attached is a patch you can use to apply the fix. Apply it from the include/CGAL directory ('patch < Bezier.diff').
It suppose to affect the following files:
Arr_traits_2/Bezier_cache.h
Arr_traits_2/Bezier_curve_2.h
Arr_traits_2/Bezier_x_monotone_2.h
Arr_traits_2/Bezier_point_2.h
Arr_Bezier_curve_traits_2.h
The problem in test case #1 can simply be avoided if you comment out the assertion on line 247 in Bezier_bounding_rational_traits.h
The problem in test case #2 happens when there exists a vertical tangency point that occurs exactly at the middle of the curve. As you can see from the size of the patch, it was a bit more difficult to fix. We hope that we eliminated the bugs or at least reduced their number...
Naturally, the fix will make it into the next release.
- Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h, David Keller, 09/13/2007
- Re: [cgal-discuss] Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h, Efraim Fogel, 09/16/2007
- Re: [cgal-discuss] Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h, David Keller, 09/17/2007
- Re: [cgal-discuss] Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h, Efraim Fogel, 09/17/2007
