cgal-discuss - Re: [cgal-discuss] Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h
  • To:
  • Subject: Re: [cgal-discuss] Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h
  • Date: Mon, 17 Sep 2007 15:49:16 +0200
Hi,
I'm appending this here, even though it is not directly related to the above discussed issues:
What is required for the stream-IO of Bezier-curve-arrangements?
____
typedef CGAL::CORE_algebraic_number_traits nt_traits;
typedef nt_traits::Rational rational;
typedef nt_traits::Algebraic algebraic;
typedef CGAL::Cartesian<rational> rational_kernel;
typedef CGAL::Cartesian<algebraic> algebraic_kernel;
typedef CGAL::Arr_Bezier_curve_traits_2<rational_kernel, algebraic_kernel, nt_traits> traits;
typedef CGAL::Arrangement_with_history_2<traits> arrangement;
arrangement a;
std::ofstream outfile( "bezier.dat" );
outfile << a ;
____
For a first try I get stuck with some compile-time errors:
/opt/CGAL-3.3.1/include/CGAL/IO/Arr_text_formatter.h: In member function ‘void CGAL::Arr_text_formatter<Arrangement_>::read_point(typename Arrangement_::Traits_2::Point_2&) [with Arrangement_ = CGAL::Arrangement_with_history_2<CGAL::Arr_Bezier_curve_traits_2<CGAL::Cartesian<CORE::BigRat>, CGAL::Cartesian<CORE::Expr>, CGAL::CORE_algebraic_number_traits, CGAL::Bezier_bounding_rational_traits<CGAL::Cartesian<CORE::BigRat> > >, CGAL::Arr_default_dcel<CGAL::Arr_Bezier_curve_traits_2<CGAL::Cartesian<CORE::BigRat>, CGAL::Cartesian<CORE::Expr>, CGAL::CORE_algebraic_number_traits, CGAL::Bezier_bounding_rational_traits<CGAL::Cartesian<CORE::BigRat> > > > >]’:
libs/bspline/test/bezier_curve.cpp:391: instantiated from here
/opt/CGAL-3.3.1/include/CGAL/IO/Arr_text_formatter.h:371: error: no match for ‘operator>>’ in ‘CGAL::Arr_text_formatter<Arrangement_>::in [with Arrangement_ = CGAL::Arrangement_with_history_2<CGAL::Arr_Bezier_curve_traits_2<CGAL::Cartesian<CORE::BigRat>, CGAL::Cartesian<CORE::Expr>, CGAL::CORE_algebraic_number_traits, CGAL::Bezier_bounding_rational_traits<CGAL::Cartesian<CORE::BigRat> > >, CGAL::Arr_default_dcel<CGAL::Arr_Bezier_curve_traits_2<CGAL::Cartesian<CORE::BigRat>, CGAL::Cartesian<CORE::Expr>, CGAL::CORE_algebraic_number_traits, CGAL::Bezier_bounding_rational_traits<CGAL::Cartesian<CORE::BigRat> > > > >]() >> p’
When trying to hunt these down it seems _Bezier_point_2 is missing some operator>> and operator<<. I cannot find these in the distribution and they are likely not trivial to add from my point of view.
Kind regards,
David Keller
