cgal-discuss - Re: [cgal-discuss] point location
  • To: <>
  • Subject: Re: [cgal-discuss] point location
  • Date: Tue, 18 Sep 2007 16:19:34 +0800
Hi, have you found it? I need the function too.
In fact, I am developing an point-in-polyhedron program for triangle based
models and I need other codes for comparison.
----- Original Message -----
To:
Sent: Tuesday, June 26, 2007 4:55 AM
Subject: [cgal-discuss] point location
> Hi CGAL Users,
> is there any method in CGAL to find out whether a point is located inside
> or outside a Polyhedron_3. I currently use a non-CGAL kd-tree for triangles
> to count the intersections of a ray. But it would be more convenient (and
> maybe faster?) if I could use a CGAL method, since I use CGAL for
> everything else.
> Thank you in advance,
> Jim
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
