- To:
- Subject: Neighbors vertices on a Polyhedron
- Date: Tue, 18 Sep 2007 15:12:33 +0200
- Organization: LPNHE - Université Paris 6 Pierre et Marie Curie
Hello,
With CGAL, is there a way to enumerate (with an iterator
or something) the neighboors of a vertex : for instance all the
first neighboors ("order 1" neighboors), the second neighboors
(neighboor of a neighboor, "order 2" neighboors), the third
neighboors ("order 3"), and so on, but without enumerating the same
vertex twice. I am a physicist, without a very deep knowledge of
graph-related mathematics; I searched in graph-literature but did
not found any simple algorithm. I need something quite fast as I
want to select all the neighboors of a given vertex of "order" less
than a fixed k, and I need to do this for all vertices, in order
to compute local physical properties (a "local plane" and other
mechanical properties).
Thanks a lot if someone could give me a hint on how to do this
in an efficient way (I may of course walk across the whole
polyhedron data structure several times, but my polyhedrons
have tens of thousands points...).
Cheers,
Laurent
Laurent LE GUILLOU Tel +33 1 44 27 39 93
Fax +33 1 44 27 46 38
GSM +33 6 20 05 75 22
Bureau 412 - Tour 33 RdC
Campus de Jussieu
4 place Jussieu
75252 Paris Cedex 05
- Neighbors vertices on a Polyhedron, Laurent Le Guillou, 09/18/2007
- Re: [cgal-discuss] Neighbors vertices on a Polyhedron, Andreas Fabri, 09/18/2007
- Re: [cgal-discuss] Neighbors vertices on a Polyhedron, Laurent Le Guillou, 09/19/2007
